28th May 2018, 7:17 pm | #1 |
E13-12 Tube pinout
Hi All,
I have an old oscilloscope I am trying to use its CRT for a different project. The Tube is listed as an E13-12, from what I have found it is also a 1324S. I have the manual for the scope, a D52, but I have not messed with CRT's much. Trying to identify the pins on the rear of the tube so I dont hook it up wrong. Any help would be appreciated. Thank you |
28th May 2018, 7:30 pm | #2 |
Re: E13-12 Tube pinout
29th May 2018, 12:55 am | #3 |
That is fantastic!!! Thank you very much. In case you wanted to have a visual of these tube, here is some pics;
E12-13/1324S/CR171 split beam tube. Seems like a very unique tube with the pins on the side of it. CRT's are a new venture, seem like fun so far. https://drive.google.com/folderview?...nNbyG-ZidHVj3M Also, the high voltage wire that has the boot on it at the front of the tube, does that need to be hooked up? Using this tube as a display, and I'm not sure if that wire is used for exactly. I know it's high voltage, but again I'm showing my ignorance with CRT's. I figured out the rest of the pins I need to use, thanks again for that schematic. Thanks again! |
29th May 2018, 11:44 pm | #4 |
The high voltage connector is for the PDA, or Post Deflection Acceleration. It applies a high voltage accelerating field AFTER the bean has been deflected left/right (X) and up/down (Y). If the beam was accelerated BEFORE the deflection, the X and Y sensitivity would be much lower. If you want a BRIGHT and well FOCUSSED spot/trace, together with a high deflection sensitivity, then PDA is you method of choice.
Les. |
29th May 2018, 11:49 pm | #5 |
Side pins for the deflectors are very common in later tube designs. They cut the stray inductance of running all connections via the base. You get much better bandwidth.
