Old 26th May 2018, 11:53 am   #1
PatMorgan
Default 20'' sinewave display?
I've various sized LCD tv's in my garage and my HiFi (s!!) all set up on various speakers. I was browsing through the home-brew section and wondered if anyone has a cost-effective soloution to display frequency on an LCD to aCt as a 'lightshow'- for entertainment purpose- a sort of oscilloscope?
I'm sure I'm not the only one to have pondered this.
PatMorgan is offline
Old 26th May 2018, 12:06 pm   #2
michamoo
michamoo's Avatar
Default Re: 20'' sinewave display?
Easiest way is to feed them with a camera pointing at an Oscilloscpe
If smoking is so bad for you, how come it cures kippers?
michamoo is online now
Old 26th May 2018, 12:09 pm   #3
Station X
Station X's Avatar
I think software is available enabling a PC to be used as a 'scope via the sound card.
You could feed the video output from the PC to the TV. Some TV's have an input enabling them to be used as a PC monitor, or you could use a convertor.
Graham. Forum Moderator
Station X is offline
Old 26th May 2018, 12:32 pm   #4
Refugee
Refugee's Avatar
In the DOS/Windows era I used to have a program that you ran after starting a music player that displayed the waveforms with various randomly added distortion effects.
It would work on any modern flat screen with a VGA input.
You just need an old DOS box to run it on.
Refugee is offline
Old 26th May 2018, 1:05 pm   #5
G6Tanuki
G6Tanuki's Avatar
I'm sure I've seen scripts to allow a Raspberry Pi to do this.
A Pi has all the hardware you'd need: audio-in, A/D converter, and HDMI output to the TV.
The rest's just software....
G6Tanuki is offline
Old 26th May 2018, 1:49 pm   #6
Refugee
Refugee's Avatar
I am pretty sure that the software could be found for almost all operating systems with a search.
Refugee is offline
Old 26th May 2018, 1:55 pm   #7
julie_m
There is no A-to-D on a Raspberry Pi. You'll need an external USB audio in device.
julie_m is offline
Old 26th May 2018, 5:06 pm   #8
G6Tanuki
G6Tanuki's Avatar
I'm sure I've seen input audio-sampling done on a Pi without an external USB audio-in or other hardware. Remember we're not after hi-fi here!
G6Tanuki is offline
Old 26th May 2018, 8:10 pm   #9
llama
llama's Avatar
SoundcardScope is a free download. I tried it as I wanted a full screen display of waveform but unfortunately is shows typical scope controls. Might do what you'd like though.
It might be called "PC-scope"
Graham
Half my stuff is junk - trouble is, I don't know which half!
llama is offline
Old 27th May 2018, 12:43 pm   #10
PatMorgan
Llama- thats just the job for the amusement/entertainment value I was looking for! Thanks everyone who answered.
Old 27th May 2018, 6:03 pm   #11
kellys_eye
(Composite) Video-toVGA converters used to be available. Would that not do the job you require?
kellys_eye is offline
Old 27th May 2018, 8:22 pm   #12
PatMorgan
I didn’t really want to use a computer/laptop- and so I wondered what might be out there as an alternative- I also don’t own a Pi but have plenty of laptops (as they are throwaway nowadays). In the w95/98 days, WINAMP used to have a ‘scope visual-
I have made a CRT display sound- as its easy, but having a large screen Plasma or LCD display would be good for AV.
There are so many cleaver individuals on here, I wondered if anyone had a CCT of a convertor.
I’m happy with the feedback I’ve received- Even putting a camera/dashcam in front of my 'scope would have worked.
The panel I've plugged into today has most inputs - the early ones had every eventuality.
Old 27th May 2018, 8:23 pm   #13
Lloyd 1985
Lloyd 1985's Avatar
Just a daft thought, Windows media player used to have ‘visualisations’ that basically made pretty patterns in time with the music, last time I remember it was back when I was using Windows XP! Might just be a case of using that on an old laptop and connect it up to the TV. I think one of the visualisations was a mock oscilloscope type display. Don’t know if they still do it in newer versions of media player?
Regards
Lloyd
Lloyd 1985 is offline
Old 27th May 2018, 10:27 pm   #14
ITAM805
ITAM805's Avatar
As Lloyd says XP and windows media player! I now use VLC but it's 'visualizations' are rubbish compared to the old WMP
ID:	163654   Click image for larger version
ITAM805 is offline
Old 28th May 2018, 1:56 am   #15
arjoll
arjoll's Avatar
Windows Media Player is still in Windows 10, and still has visualisations.
ID:	163659   Click image for larger version
ID:	163660   Click image for larger version
ID:	163661   Click image for larger version
arjoll is offline
Old 30th May 2018, 7:05 am   #16
Diabolical Artificer
Diabolical Artificer's Avatar
Am sure I have an old Elektor/ETI somewhere that had a audio visualization gadget that showed groovey changing patterns on your tele. From memory they weren't very far out, just diamond shapes.
Also dredging the memory banks i think Techmoan featured a commercial device that did the same not long back.
For the ultimate scope display see - https://www.youtube.com/watch?v=19jv0HM92kw which we've covered before here on UKVRR
Andy.
Old 30th May 2018, 10:02 pm   #17
PatMorgan
Thanks Andy- I saw the same review of the Scope that he showed/demonstrated- its probably what sparked my request! There is some good stuff on Techmoans feed.
Old 31st May 2018, 4:12 am   #18
Terry_VK5TM
Terry_VK5TM's Avatar
I built the Elektor one and couldn't get it to work at the time, probably still in a box somewhere if I haven't recycled the parts.
Will have a dig and see if I can find the article.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is online now
Old 31st May 2018, 6:36 am   #19
"There is some good stuff on Techmoans feed." He does good video's, well polished, must take him ages.
Audio visualization I found a bit heavy on the eyeballs, unless you had a suitable muscle relaxent, like 8 pints of Shipstones or Bass as suitable to hitching a ride on a Vogon spaceship. The Elektor project I guess was partly influenced by psychadelic's ( and cheap IC's) , but unless you've dropped a trip, tends to get boring. Those visualization's on WMP are good, but again you still need something other than Old Peculiar to appreciate them. Mind you I once had some 12 year old homemade wine that was decidedly mind altering.
I guess nowadays a laser display would be practical at home, but maybe not a good idea, lest you blind the cat or the missus : )
If anyone's interested in the Elektor article and Terry can't find it, I'll see if I can find it.
Andy
Old 31st May 2018, 8:14 am   #20
kellys_eye
IIRC the Elektor one put Lissajous figures on-screen using two adjustable sinewave oscillators that themselves were modulated Might be mistaking it for another project though. I do recall making one back in 86(?) though.
