Old 27th Feb 2018, 8:56 am   #1
mickyfinn
Default Teac A3440 problems
From forum searches there appears to be some members very familiar with this deck. I would be very grateful for any suggestions how to get mine up and running.
First of all I have actually had the rare occasions when most functions have worked fine. These occasions gave me the chance to test it enough to ascertain that it can record and playback that recording and play a tape recorded on another device.
Most of the time I have the following faults......
Rewind only works for a second or two, pressing stop causes it to rewind again for a second or two. FF works fine. With the tape removed from the heads i.e directly from spool to spool Rew and FF work fine? Machine only uses a counter belt and capstan belt, spools have their own motors.
In play after a few seconds the tape stops, this causes slack which makes the switch lever to drop shutting off the capstan motor.
As I said earlier very rarely both play and rewind will work fine but it doesn't last.
When it's behaving the brakes work fine, counter works ,pause in record works, all meters work etc. Any thoughts or suggestions will be appreciated. Forgot to mention I thoroughly cleaned the tape path and heads with IPA.
Mick
mickyfinn is offline
Old 1st Mar 2018, 8:37 am   #2
mickyfinn
Default Re: Teac A3440 problems
Appears that all the problems were due to a sticking solenoid on the RH brake.
Mick
