27th Nov 2014, 8:47 pm | #1 |
Colossus - Valves
At Bletchley Park - Does anyone know which were the most commonly used triode valves with topcap connections & IO bases, please ?
Regards, David |
27th Nov 2014, 9:01 pm | #2 |
Re: Colossus - Valves
I know that the colossus used EF36 pentodes because I donated some a while back. I don't know if it used any triodes though, but someone will.
27th Nov 2014, 9:14 pm | #3 |
Yes, my understanding also is that Colossus was built around hundreds of EF36s. They were just doing logic so you'd expect them to have used lots of double triodes, but I suppose they just used whatever was easily available. The EF36/37/37A always had a reputation as a reliable valve so maybe that was a factor.
27th Nov 2014, 10:27 pm | #4 |
EF36/37/37A for general small signal use. They used 807s as relay drivers and also used some thyratrons if I remember. The 807s have top caps, but they are beam tetrodes.
27th Nov 2014, 10:49 pm | #5 |
I expect the thyratrons were T41s as they were prolific on the WWII surplus market and captivated my youthful interest to use them a lamp dimmers followed later by SCRs.
27th Nov 2014, 11:03 pm | #6 |
6J5 is octal triode with top cap grid.
Don't know whether Colossus used any.
28th Nov 2014, 12:16 am | #7 |
The 6J5 does not have a top cap. It is half a 6SN7. J.
28th Nov 2014, 1:48 am | #8 |
I would have expected Colossus to use lots of 6SN7s, but presumably they were in short supply, or designers were reluctant to use an American valve in such a classified project. I don't know to what extent the Americans were embedded at Bletchley - they may have been kept at arm's length.
28th Nov 2014, 11:29 am | #9 |
Perhaps Flowers used those valves that he had found by experience to be reliable? Also the choice may have been determined by what Dollis Hill had in stores - and that could be used in large numbers without raising comments?
28th Nov 2014, 1:10 pm | #10 |
It also used large quantities of those lovely little diodes, the EA50, or whatever its CV number was.
I was able to supply them with many dozens of assorted valves for the rebuild of Colossus and for the EDSAC project. |
28th Nov 2014, 2:19 pm | #11 |
I visited Bletchley Park earlier this year - well worth it. They are still interested in valve donations for Colossus and I did make a note of what they wanted - I'll post it here when I lay my hands on it
Meanwhile there's a very good description of Colossus in this PDF document http://www.cs.ncl.ac.uk/publications...papers/133.pdf from Newcastle University. It shows some circuit samples eg EF36 Adder. |
28th Nov 2014, 2:21 pm | #12 |
Thanks Guys, for info.
Actually, a pal contacted me to see if I had any triodes with a topcap, which would've been used in Colossus. They wanted one for a Christmas present for someone's scientific photographic project, and it didn't matter if the valve was u/s. I too thought that the ECC3-series of older triodes would've been more likely. The only single triodes I have from that era are GT's. I do have a decent spare working CV63, but obviously don't wish to lose it to a picture project. Likewise - a number of decent 807's. The pictures of Colossus which my pal sent showed a number of Red Mullards, which looked like EL types. However, he's convinced that a red triode valve with a topcap is what this person wants. I've just had a jolly good clear-out of duff valves, so I'll tell him to try elsewhere. Regards, David |
28th Nov 2014, 2:39 pm | #13 |
The thyratrons were Marconi-Osram GT1-C type.
Other types used were indeed mainly EF36/37 and 807's, although equivalent types to EF36/37 may also have been used considering the sheer numbers required for all the colossus machines actually made. |
28th Nov 2014, 2:42 pm | #14 | |
Oops! Should be 6F5G. Perhaps an EBC33 would do? That's the same red as the EF37s etc. Just a couple of extra diodes to forget. Or perhaps an H63?
28th Nov 2014, 2:52 pm | #15 |
It's worth remembering that colossus was built in wartime and that many of the valves would have been CV equivalents of the civvy valves.
Therefore, many of the valves in the original machines would actually have been "CV grey", not red. |
28th Nov 2014, 3:23 pm | #16 | |
The secret nature of the project would presumably have been a factor in how and where the valves were sourced. |
29th Nov 2014, 1:00 pm | #17 |
HI,
Tommy Flowers, the designer of colossus, was a General Post Office employee so I think that the Post Office stores system was the most likely source of the valves |
29th Nov 2014, 7:59 pm | #18 |
The EL37A has the grey CV358 as the military equivalent.
I have one that has lost the grey coating and with a bit of T-cut the internal view can be seen. |
30th Nov 2014, 12:53 am | #19 |
30th Nov 2014, 9:40 am | #20 |
Bletchley Park Ltd
The Mansion Bletchley Park Milton Keynes MK3 6EB |
