9th Jul 2020, 12:59 pm | #1 |
Revox A77 Playback Problem
Hi, I have a Revox A77 which I'm trying to get working again. It's got an issue with one of the Repr Amps. It was completely dead with no playback at all. I've changed the tantalum capacitors as two of them had shorted and also the electrolytics. There is now playback when I select 'input' but not from the tape. If I swap the card for a good one I get playback from input and the tape. I don't have a scope so can't test it properly. Is there a part or parts that could cause this issue? Thanks Christian
9th Jul 2020, 11:49 pm | #2 |
Re: Revox A77 Playback Problem
Transistors have been known to fail, i suppose resistors could go high, A more likely cause is the preset pot for the reproduce level. The slider breaks off so you get no output. Its a simple thing to replace.
10th Jul 2020, 6:13 am | #3 |
To add, as always check the polarity orientation of the capacitors you have replaced.
10th Jul 2020, 7:30 pm | #4 |
Thanks. It was the preset pot. It looked fine but wasn’t making contact. Now it’s fallen apart completely.
