Old 19th Jul 2021, 12:58 pm   #1
nightowl
Default Lotus SG4 portable
We've just inherited one of the above, there's a few edges of the box covering that's perished over time (it's been in a garage for donkeys....). thought people might want to have a looksy.
If I ever got anyone to get it working again, are there modern versions of the batteries they use to use about?
ID:	237938   Click image for larger version
ID:	237939   Click image for larger version
ID:	237940   Click image for larger version
ID:	237941   Click image for larger version
nightowl is offline
Old 19th Jul 2021, 2:12 pm   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: Lotus SG4 portable
Nice set.
Yes the 2V lead acid accumulator can be replaced by a Cyclon or similar.
https://batterygroup.co.uk/Batteries...battery-E-cell
The HT battery can be made up by series connecting a load of PP3's (you will probably need 15 or 16 assuming the HT is 120V and use a lower tap as necessary for the detector.
And the Grid Bias Battery can be made up from 6 series connected AAA batteries as you will need to select a suitable tap.
Make them up into suitable scanned cases and they will look the business
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 19th Jul 2021, 9:44 pm   #3
nightowl
thanks for that mike, I looked the lotus up last night, the battery looks like 1 big pin board like the telephone exchange women use to work, so that's 3 batteries inside the 1 case ?
attached some photos of the working parts of the old girl......
ID:	237969   Click image for larger version
ID:	237970   Click image for larger version
ID:	237971   Click image for larger version
nightowl is offline
Old 19th Jul 2021, 10:25 pm   #4
Cobaltblue
Cobaltblue's Avatar
I guess your looking at this picture you can see 3 Batteries
The Big one is the HT (in Red) these often had multiple taps making them suitable for many different sets and valve types.
The Blue one is the Grid Bias it looks as if this has two taps in use.
Lastly the green is the LT accumulator usually a Gel type in portable sets.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 19th Jul 2021, 10:45 pm   #5
nightowl
aye that's the one(or 3)...... were Lotus top middle or bottom of the range equipment back in the day? When I first saw the case I thought it was going to be a gramaphone, but was quite surprised when it was opened.....
nightowl is offline
Old 22nd Jul 2021, 12:12 pm   #6
PJL
Before you go any further, you need to check the continuity of the inter-valve transformer and speaker coil as these often fail in suitcase portables due to the battery fumes rotting the copper wire. For a price they can be rewound but it's best to know up front what you are getting into.
PJL is offline
Old 23rd Jul 2021, 12:11 pm   #7
Gridiron
The fixed resistors also may require checking and the blue painted Dubilier cap will probably be very leaky.
Gridiron is offline
Old 24th Jul 2021, 7:55 am   #8
nightowl
tar muchly, yeah I will get a person that is old technology savy to give it a look over as I am a novices novice when it comes to W/T stuffs......I've not even looked at the speaker innards tbh.....the latches would they have been some sort of chrome or just silver painted (the drawings of them they look light coloured) ?
nightowl is offline
Old 24th Jul 2021, 10:09 am   #9
Herald1360
Herald1360's Avatar
Possibly nickel plated given its age. Unlikely to be just painted at any rate.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 24th Jul 2021, 10:21 pm   #10
nightowl
What would be the best DIY way of returning the latches etc to their former glory?
nightowl is offline
Old 25th Jul 2021, 11:07 am   #11
Richardgr
I think you have to be careful not to destroy the 'patina' of this radio. It looks to be in an excellent state for its age, and could be devalued by overdoing the renovation.
It is worth thinking about your long term strategy, and seeing if there is a market for this one. Sometimes it is more fun to pick up wrecks, in the knowledge that one can learn without the responsibility of having something that is irreplaceable!
Richardgr is offline
Old 1st Aug 2021, 7:05 pm   #12
nightowl
the clasps/hinges condition at the moment.
ID:	238636   Click image for larger version
ID:	238637   Click image for larger version
nightowl is offline
Old 1st Aug 2021, 8:38 pm   #13
Paul_RK
Paul_RK's Avatar
My little "Receiver Specifications and Prices" books are currently in hiding, but I'd say middle or just above from the sets I've seen. They were quite a small company and didn't go in for any very ambitious designs, but build quality was solid and they didn't generally skimp on cabinets and finish. Bear in mind that suitcase portables as a class of radios were mainly the preserve of the fairly well heeled. Few would have chosen one as their sole household set, even where mains electricity wasn't available: and period ads often show them in use out and about, at a time when there were only around a million cars in the UK. I suspect they've survived better than table or floor-standing models of the period on account of their being relatively easy to close up, put away in cupboard or attic and forget about.
Paul
Paul_RK is offline
Old 14th Aug 2021, 4:37 pm   #14
nightowl
tar muchly Paul....
nightowl is offline
