Reply
Old 12th Jun 2021, 7:08 pm   #1
BrianAllen
Default Strength of Solder for Soldering Bowden Cable Wire Nipples?
Just a quickie.
Can I use the same type solder we use for soldering wire for soldering nipples to Bowden cable wire?
Brian
BrianAllen is offline   Reply With Quote
Old 12th Jun 2021, 7:15 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: Strength of Solder for Soldering Bowden Cable Wire Nipples?
What's the wire made of?
If it's steel or - even worse - stainless-steel - you will have problems getting ordinary solder to adhere to it.
[When I re-strung the dial drive on my Eddystone 840A rather than using any kind of solder I dismantled a bunch of 5-amp 'choc-block' connectors and sawed each of the barrels in half to produce a single-screw version; these worked just fine and have the advantage that you can release-and-retighten them if you need to take up a bit of slack]
G6Tanuki is online now   Reply With Quote
Old 12th Jun 2021, 7:23 pm   #3
BrianAllen
Just ordinary steel I think; definitely not stainless.
What a good idea, I like the idea of being able to release and re-tighten.
Thank you.
Brian
Old 12th Jun 2021, 9:37 pm   #4
kalee20
I've used standard electronics grade 60/40 solder for bike brake cables. Obviously, the cable must be clean, and spread out inside the nipple. I've never had one pull off.
But - I don't know how well lead-free electronic solder would work. It's not clear from your original post what you mean by "the same type solder we use for soldering wire," hopefully then this answer covers both eventualities!
kalee20 is online now   Reply With Quote
Old 12th Jun 2021, 9:38 pm   #5
Refugee
Refugee's Avatar
Last time I did one I used a crimp solder tag.
The ring part could be cut down if it makes threading easier.
Refugee is online now   Reply With Quote
Old 13th Jun 2021, 3:46 am   #6
TonyDuell
When I needed a cable for the cover latch on my R80 disk drive I did what G6tanuki suggests and used cut-down 'chocolate block' innards. Seems to work fine.
The nipples I bought were designed for use on a bicycle and seem to be aluminium. No solder would stick to them anyway. So I didn't bother to check if the solder would stick to the cable or not.
TonyDuell is offline   Reply With Quote
Old 13th Jun 2021, 5:41 am   #7
trevatxtal
"" the cable must be clean, and spread out inside the nipple"".
If the solder flows and the strands spread then it will not fail.
The adjustable clamp (however made) is a much better idea.
trevatxtal is offline   Reply With Quote
Old 13th Jun 2021, 6:37 am   #8
Restoration73
Restoration73's Avatar
Trouble with 60/40 is it is ductile. A higher melting point 40/60 type is less so, a good
temperature controlled iron (or gas type) may be needed.
Restoration73 is offline   Reply With Quote
Old 13th Jun 2021, 8:05 am   #9
Radio Wrangler
Radio Wrangler's Avatar
If you're going to gas heat, then silver solder might as well be used. It's a lot less ductile and shouldn't have a creep failure mode like soft solders.
Parts fail when under most stress, so nipples pull off when they're being used. For a bike brake this can be very dangerous. Soft solder would be worrying in some applications.
Radio Wrangler is online now   Reply With Quote
Old 13th Jun 2021, 10:11 am   #10
ms660
ms660's Avatar
Inserted into a coupling then filled with a Tin alloy (white metal) very very strong, no pullie out.
Lawrence.
ms660 is online now   Reply With Quote
Old 13th Jun 2021, 6:10 pm   #11
MotorBikeLes
I have been soldering motorcycle cables for the last 60 years, most of the time using normal electronics multicore. With some older stuff, with a hint of rust around, you will need some Bakers fluid to be sure of a good joint. As mentioned above, the creation of a "ball" in the Bowden cable is the guarantor of long lasting success. I have seen stainless steel, but never on a motorcycle, but possibly an acid fluxed wire would be OK provided wire "balled" properly. I have made all my own cables for most of this time and still do.
Les.
MotorBikeLes is offline   Reply With Quote
Reply
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
