9th Mar 2021, 6:16 pm | #1 |
Anyone know what this is?
Does anyone know what model this radio is?
The closest I can find is the Philips 341A but all the ones I have seen are black and have slightly different knobs on the front. I got it in a house clearance and just want to find some more information on it as I don't know much about these things. Thanks in advance |
9th Mar 2021, 7:06 pm | #2 |
Re: Anyone know what this is?
9th Mar 2021, 7:06 pm | #3 |
Hi there, It's a Philips B3G74A It looks to be in very good condition, usually the paint is badly chipped/falling off!
9th Mar 2021, 8:36 pm | #4 |
Please DON'T just plug it in to see if it works. You may cause expensive damage to what is otherwise a very nice set.
Have a read of the stickies about restoring sets and have a go yourself if you have the knowledge to try; failing that there are folk on here who will assist you. Ed |
9th Mar 2021, 9:08 pm | #5 |
Thank you so much for your replies!
9th Mar 2021, 9:11 pm | #6 |
Thank you for your warning.. unfortunately I had already plugged in and turned on as I didn't realise I shouldn't! It did work and I spent the afternoon listening to the one radio station I could find on it. Should I now leave it turned off until I can get it restored or does that mean it's okay to use?
9th Mar 2021, 9:29 pm | #7 |
Don't think those knobs are original....too modern. As advised DON'T PLUG IT IN to see if it works. It will need fully servicing after all these years.
9th Mar 2021, 9:36 pm | #8 | |
Of course, it's possible that the previous owner had some or all of the caps replaced - quite likely if they were a vintage radio enthusiast. |
9th Mar 2021, 11:16 pm | #9 |
They do, however, look identical to the knobs on the one Herald1360 linked to at radiomuseum.org.
10th Mar 2021, 7:47 am | #10 |
Yes, the knobs are original. They seem to go brittle and chip around the edge. This was my one.
10th Mar 2021, 10:59 am | #11 |
What a lovely radio! As others have said it is probably a good idea to have it checked over.
As to if the capacitors are in need of replacement a lot depends on how the set has been kept. If it has always been kept in the warm and used from time to time the capacitors will be in better condition to a set that has been in a unheated damp area . If the capacitors are in need of replacement particularly the one in the amplifier that causes problems I would have thought the sound would have gone distorted and low volume after running for a while. If the capacitors in the receiver side have deteriorated you may get various howls and whistles and or popping noises with the reception dropping in and out as you tune it. I don't always think replacing all of the capacitors as a matter of course always applies in every case... I am sure others will have a different opinion though. I have a Philips set with the same "black tar" capacitors I have owned it for 30 years or so it's always been kept in the warm and dry . It works perfectly with all of its original capacitors still in place. I have no intention of replacing them unless the set shows signs of problems. Rich |
10th Mar 2021, 6:55 pm | #12 |
Thanks everyone you've been a great help!
