13th Feb 2005, 9:26 pm | #1 |
Can a 6V6 be substituted for an EL84?
I have a couple of output transformers, ultralinear, intended for use with EL84.
I fancy making a pair of amplifiers using 6V6 again - and I wonder if the 6V6 would work in place of the EL84s? I seem to recall someone, somwhere, a long time ago saying they had substituted one for the other, and they had no problems. Has anyone tried this? David |
13th Feb 2005, 10:05 pm | #2 |
Administrator
Re: Can a 6V6 be substituted for an EL84?
According to the Mullard data, as a single-ended class-A amp, for the 6V6 Ra = 5k and Pout = 4.5w (at 250V), and for EL84 Ra = 4.5k to 5.2k, and Pout = 5.7w.
I don't know how these would relate to a class-AB amp, but it does suggest that the characteristics are rather similar. |
14th Feb 2005, 2:27 am | #3 |
Thank-you, both!
In that case I'll press ahead and give it a whirl. I suspect the transformers were optimised for the EL84s, but the 6V6s certainly don't seem a long way out ... And they are Octals. The first amplifier I ever built used a pair of 6V6 in push-pull, with a 6SN7 and an E37A. It was for my youth club, and I remember dancing to the first record we played through it .... Francoise Hardy's "All over the world". I was 13. Francoise Hardy still gives me goose bumps! And that pair of 6V6s took a huge amount of stick for years and years. David I'll keep an eye on the biasing. David |
14th Feb 2005, 8:30 am | #4 |
You want something for your eyes, take the 6V6.
You want something for your ears, take the EL84. Darius |
