30th Aug 2020, 1:54 pm | #41 |
Re: Philips 141U
Actually, the HT being 20V or so down won't make a lot of difference. The heater voltages are much more critical.
There isn't any substitute for a UY41 unless you want to change the valve base. You could replace it with a 1N4007 and 100-200 ohm resistor, leaving the valve heater in circuit to keep the heater chain working and for cosmetic effect. If you do this, check that the smoothing electrolytics aren't being subjected to excess voltage before the valves warm up. |
2nd Sep 2020, 9:58 am | #42 |
Re: Philips 141U
Having concluded that I had taken the Philips 141U as far as I could while accepting that the set had a low emission rectifier I put it all back in the case and turned it on.
But two new issues:- 1. I now have a loud hum that wasn't there previously which is independent of the volume? Initially the set hummed badly but this all but disappeared when I replaced the reservoir and smoothing caps. Took the chassis and speaker back out the case and there is still a residual background hum but which is probably acceptable. But when I try to reintroduce the speaker into the case the hum increases to an unacceptable level - it's as if the case is amplifying the hum? So this is bizarre and I need to find a way to fix the residual background hum or work out the means by which the case is apparently amplifying this hum and fix that?? 2. The set is running very hot with the Bakelite on the top and back being too hot to touch! You may remember that I had a broken section of the Dropper which was bridged with a 240Ω 10W ceramic cement resistor. The majority of the heat, however, does appear to be emanating from V5 (UY41) and V4 (UL41) - their respective heater voltages are 31.2V and 47.2V. Although this set has a fairly standard valve line-up the case is relatively small in comparison with e.g. the Bush DAC90A, so this won't be helping? I need to investigate some means of reducing the heat output - is there such a thing as a heat resistant sheet that I can apply to the inside of the set? The intended recipients of this set have small children so I don't want to introduce a potential burning hazard to their home! Any ideas warmly welcomed - pardon the pun ... ?
BVWS Member |
2nd Sep 2020, 10:17 am | #43 |
Re: Philips 141U
Try a different UL41. Sometimes they develop an intermittent internal leak which causes humming.
All radios of this type run hot. There are a number of techniques you can use to reduce this: Replace the dropper with a capacitive or diode dropper: https://www.vintage-radio.com/repair...per-calcs.html Increase the UL41 cathode resistor Bypass the UY41 with a silicon diode I would be wary of using a radio of this type where there are small children around though. Some sort of repro fake vintage set would be a better choice. |
2nd Sep 2020, 11:28 am | #44 | ||
Re: Philips 141U
Measure the voltage across the cathode resistor of the UL41 and then work out the current. I think the UL41 maximum anode current is around 45mA and screen grid is about 10mA so measuring the voltage drop across the cathode resistor and then working out the current will be the TOTAL current of anode and screen grid. It will soon reveal if the UL41 is drawing excessive current. A total current of around 35 - 40mA drawn by the valve would probably be normal. If it's less, that's OK as well (as long as it's not too much less). Anything much more and I'd try another UL41. With regard to using one of these near children....I would be VERY careful. They have wandering fingers and curious eyes. If it was me I would agree with Paul Sherwin and use a repro and keep this for use in another room.
2nd Sep 2020, 1:30 pm | #45 | ||
Re: Philips 141U
As for replacing the existing Dropper with a capacitive or diode dropper - I skimmed the document you provided the link to and this will need some serious consideration before I venture down that road! I understand that there is a bit of maths involved (not a problem), although a helpful spreadsheet is included, I forsee challenges in transferring the theory to my real world example where I have a Dropper with several resistive sections! The important point about small children and vintage valve radios is well made here and in many other Threads - noted.
BVWS Member |
2nd Sep 2020, 1:37 pm | #46 |
Re: Philips 141U
The dropper calculations are made easier because very large numbers of 50s radios used the same valve lineup, so the work has already been done.
2nd Sep 2020, 6:18 pm | #47 | ||
Re: Philips 141U
BVWS Member |
2nd Sep 2020, 6:56 pm | #48 |
Re: Philips 141U
That will reduce the maximum volume, but it won't be noticeable in normal use. Going from 3W to 1.5W is only -3dB.
59mA does seem a bit high. Have you checked that there aren't significant +ve volts on the UL41 grid? This can be caused by a leaky coupling cap, but also by internal leakage in the valve. |
2nd Sep 2020, 7:40 pm | #49 |
Re: Philips 141U
Of course the audio coupling capacitor was the first thing that was replaced.
I will, however, go back and check for leakage. Remind me, do I measure Grid to Chassis or Grid to Cathode?
BVWS Member |
2nd Sep 2020, 10:12 pm | #51 |
Re: Philips 141U
Yes, that's OK. I would certainly bump up the cathode resistor. Standard practice at the time was to run the output valve absolutely full pelt, but a small radio like this will be rattling like mad with 3.5W going into the speaker. 500mW would still be quite loud for normal listening.
3rd Sep 2020, 3:05 pm | #52 |
Re: Philips 141U
Increased the cathode resistor (R17) to 220Ω from 150Ω and the voltage across the resistor increased from 8.9V to 11.1V ?
This means that the current changed from 59mA to 50mA. (8.9/150 = 0.059A and 11.1/220 = 0.05A) I am confused though as this means that the Wattage increased from 525mW to 555mW, assuming my calculations are correct? (8.9 x 0.059 = 0.525W and 11.1 x 0.05 = 0.555W) I'm measuring 14mV (millivolts) on the Grid (Pin 6) of the UL41.
BVWS Member |
3rd Sep 2020, 3:21 pm | #53 |
Re: Philips 141U
The resistor is dropping more voltage so is dissipating slightly more power. You can try increasing it to (say) 300 ohms if you like. You probably won't be able to hear the difference, the radio will run cooler and the UL41 will last longer.
3rd Sep 2020, 4:48 pm | #54 |
Re: Philips 141U
Thanks Paul - understood.
I think we might have one last push with this set while it's out the case and increase the cathode resistor to 300Ω. Of course I don't have any of that value in my supplies so on order!
BVWS Member |
3rd Sep 2020, 5:18 pm | #55 |
Re: Philips 141U
It's not at all critical. Have a play with whatever you've got.
7th Sep 2020, 8:19 pm | #56 | |
Re: Philips 141U
This means that the current changed to 42.6mA (12.8/300 = 0.0426A) - much better! So not only is the resistor dropping more voltage but the Wattage (power dissipation) stays about the same (0.0426 x 12.8 = 0.545W previously 0.0555W). As Paul predicted in his Post above I'm not able to discern any reduction in volume. Time to get everything back in the case, again, to see (feel) if the radio is running any cooler and hear how the hum is getting on!
BVWS Member |
20th Sep 2020, 12:03 pm | #58 |
Re: Philips 141U
Well done Donald, Just goes to show that perseverance and dedication comes to the fore in something like this.
Ken |
12th Jun 2023, 10:10 am | #59 |
Philips 141U - Revisited
Can't believe that it was way back in July 2020 that I successfully restored this Philips 141U for a friend, with the help of Forum members of course:-
Unfortunately the radio was returned to me this week, the symptoms being completely dead and no sign of life whatsoever? A quick perusal of my earlier thread gave me a 'step-to-a-hint' as to where the problem might lie as the set did run very hot and part of the Dropper had already been bridged. Sure enough another section of the Dropper was showing O.L. on my DMM - R3 should be 250 Ohms according to the Service Sheet! Temporarily bodged in a 2W resistor just as a quick test and the radio came to life but we need a more permanent and robust solution now that two of the Dropper's three sections had failed- it is only a matter of time! So don't know if I should:- 1. Advertise for a replacement Dropper on the Forum? 2. Obtain a 250 Ohms 5W replacement to 'fix' the problem - yet another bridge? 3. Look at alternatives to the Dropper as this set does run very hot? Of course I'm tempted by 3. as I've never tried that before! I did look at Paul Stenning's Dropper Calculations page and concluded that a Capacitive Dropper would seem to be most appropriate for this set but I am somewhat overwhelmed by the technical details and calculations, especially where we have a number of tappings to contend with? Then I started thinking about what else could I do in addition to a Capacitive Dropper to reduce the heat output and I remembered that back in my original Thread Paul Sherwin had mentioned 'There isn't any substitute for a UY41 unless you want to change the valve base. You could replace it with a 1N4007 and 100-200 ohm resistor, leaving the valve heater in circuit to keep the heater chain working and for cosmetic effect. If you do this, check that the smoothing electrolytics aren't being subjected to excess voltage before the valves warm up.' - but I'm getting ahead of myself as usual!
BVWS Member Last edited by Station X; 12th Jun 2023 at 12:05 pm. Reason: Threads merged. |
12th Jun 2023, 10:37 am | #60 |
Re: Philips 141U - Revisited
For a capacitor dropper ignore the taps just use the nominal mains voltage, eg: 240 Volts for the calculation.
Lawrence. |
