29th Oct 2017, 4:11 pm | #1 |
Grundig mic identity.
I have a Grundig microphone that came with the Uher 4000L tape recorder which was the subject of a recent thread. I'm curious as to what type it is, as it looks like it may be a studio type. It has a large-ish threaded hole in the base for fitting to a mic stand, a fairly long lead with a three pin DIN plug. This latter has a yellow identifying marker, as does the mic itself. The mic is 'double sided' which makes me think it might have a figure-of-eight pick up pattern and possibly designed to be surrounded by actors, singers, etc. Cheers, Pete.
29th Oct 2017, 4:28 pm | #2 |
Re: Grundig mic identity.
Looks similar to half of one of these?:
https://www.radiomuseum.org/r/grundi..._gdsm_202.html Lawrence. |
1st Nov 2017, 11:16 am | #3 |
Hi Lawrence, and thanks for the info.
So, it's half of a stereo pair, hence the colour identifier. Cheers, Pete.
1st Nov 2017, 2:27 pm | #4 |
If it's half a stereo pair, it's probably a cardioid pickup pattern type.
1st Nov 2017, 2:40 pm | #5 |
Tractorfan
It's a GDM 101 and can be viewed on the Grundig tribute site, the link below is for microphones only http://www.taperecorders.nl/micro.htm Here's the lnk to the whole site and it's quite interesting http://www.taperecorders.nl/
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
2nd Nov 2017, 2:52 am | #6 |
Beautiful! There is even a little impedance-matching transformer right inside the DIN plug!
Many manufacturers supplied crystal mics with their valve-based reel-to-reel recorders (good because they are high-output, high-impedance devices inherently suited to a valve input stage; bad because their performance is naturally limited) but Grundig always preferred to supply better-quality microphones; dynamic or even condenser types (the latter requiring a HT supply via a specially-wired DIN connector, a possible trap for the unwary). Exactly how much real benefit this conferred given the limitations of half-track recording at 9.5cm./sec. probably is debatable, since good quality crystal microphones certainly existed, but it was certainly perceived as worthwhile. The microphone supplied with the TK14 was a very nice dynamic one with a step-up transformer to suit a high-impedance input on pin 1, with a direct connection for a low-impedance input on pin 3. This suits the Uher 4000 series, and the Grundig mic gave an excellent account of itself with the more capable recorder.
