Old 24th Nov 2017, 12:38 am   #21
Terry_VK5TM
Terry_VK5TM's Avatar
Default Re: Cleaning PCB track side?
Yes, that's the style, thanks.
I'll have to see if there is a local Faber-Castell outlet that has them, £9.99 postage for O/s deliveries is a bit steep.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 24th Nov 2017, 2:33 pm   #22
GW4FRX
GW4FRX's Avatar
To lift an oxide, it's going to take something like...citric acid, or physical abrasion.
Sainsbury's lemon juice on the end of a cotton bud doesn't seem to work but maybe it's not acidic enough. Our local Wilko sells citric acid powder so I'll try that.
GW4FRX is offline
Old 25th Nov 2017, 1:49 am   #23
julie_m
Fibre glass pencils are very good for cleaning the things nothing else will touch; but 88, then you will &dust they produce really is an industrial-stength itching powder. Watch how you clean it up after use, you absolutely do not want just to spread this stuff around. If you have sensitive or damaged skin, eczema or skin allergies, be extra careful. Even if you think your skin is as tough as leather, be careful .....
julie_m is offline
Old 25th Nov 2017, 2:53 am   #24
G8UWM-MildMartin
I must admit to having had several unpleasant experiences using the fibre glass (or glass fibre) pencils that I wouldn't wish on anyone here, but the brass wire inserts for the same are no problem, though less effective.
G8UWM-MildMartin is offline
Old 25th Nov 2017, 2:48 pm   #25
GW4FRX
GW4FRX's Avatar
Tried dissolving one tablespoon of Wilko citric-acid powder in 50ml of hot water and applying via cotton bud. No effect on oxidation even with hard rubbing. Also tried glass-fibre pencil on a scrap PCB. This very effectively removed the entire tinning layer leaving pink-coloured copper beneath, so judged not safe for use on Radford board.
Can anything be done chemically, perhaps with tinning solution? Or perhaps via an ultrasonic bath?
GW4FRX is offline
Old 25th Nov 2017, 4:53 pm   #26
ex seismic
RS used to (and may still) do an abrasive loaded rubber block specifically for cleaning PCBs. Just like an ordinary eraser but gritty to the touch and much kinder to the trousers.
Also very good for cleaning model train tracks.
Gordon
ex seismic is offline
Old 25th Nov 2017, 6:00 pm   #27
Goldie99
I still have an abrasive mica loaded rubber block that I bought years ago - it's excellent for removing surface rust from old steel especially, and I suspect is the type of product you mean. Unfortunately, I bought it 20 years ago, abroad, and have no idea what it was called...
A somewhat milder option may be steel wool ? it's abrasive, but the finer grades are fine enough for high quality wood finishing, so it should be suitable for an older PCB.
Goldie99 is offline
Old 25th Nov 2017, 8:16 pm   #28
GW4FRX
GW4FRX's Avatar
Nearest I can see in RS is http://docs-europe.electrocomponents...6b81513e28.pdf Does this look like the block you have?
GW4FRX is offline
Old 25th Nov 2017, 8:24 pm   #29
Goldie99
I think the one I have is coarser, but if anything the RS one you've found looks better suited for what's needed here.
Goldie99 is offline
Old 25th Nov 2017, 8:53 pm   #30
GW4FRX
GW4FRX's Avatar
Many thanks. I'll give it a go.
Was wondering whether something like http://nerdclub-uk.blogspot.co.uk/20...ng-powder.html could be used on a partly populated board if one was careful. Anyone tried it?
GW4FRX is offline
Old 25th Nov 2017, 9:23 pm   #31
Pamphonica
Pamphonica's Avatar
The blocks of fine abrasive in something like rubber used to be called Polifix. The modern RS ones are fine. I use them often, to burnish edge contacts or take tarnish off or clean up new pcbs. They are meant to be safe even on gold edge connectors. Worth a try for a very few ££.
Pamphonica is offline
