27th Sep 2020, 9:06 pm | #1 |
1950’s Crypton engine analyser
Would anyone have any information relating to the above mentioned test set?
There is a ‘scope, volts, amps, exhaust gas tester, rpm and dwell functions. So far I have checked the ac input box (20 odd pounds of choke and transformers) and after removing the tubes, checked the transformer output. I’ll need to remove the CRT and look for a part number so I can start tracking down pi outs and test that. I’ve attached a front photo as well as the data plate. Anyone seen one of these before? |
27th Sep 2020, 11:09 pm | #2 |
Re: 1950’s Crypton engine analyser
Not the same model, but you may get some ideas: https://www.vintage-radio.net/forum/...d.php?t=165804
28th Sep 2020, 12:29 am | #3 |
Thanks, I've read through the post, and managed to contact the gentleman referred to.
Unfortunantly he does not have anything for this (much older) model. It doesn't look too complicated, just a matter of tracing it out. Anyone know a good source for .15uf 3KV DC caps? |
30th Sep 2020, 4:01 am | #4 |
Well, testing continues. The CRT quick tested ok. About 3.55V after 15 seconds or so. The heater volatges are all good, and the big power supply caps reformed well. HV seems to be missing, possibly a dud tube, but until I get another one I can't really tell.
This is fun, it's been a while since I did something like this. |
6th Oct 2020, 9:11 pm | #5 |
It's worth a punt to see if the current company manifestation has any information:
https://www.cryptontechnology.com/why-crypton/history They may like some photos for their archive! JOhn |
