Old 7th Apr 2018, 6:42 pm   #1
stuart_morgan_64
Default Electronic microphone circuit.
I have built a few of these and work very well. At the moment the gain is too high. Needs to be about half what it is now. What do I need to adjust, change to do this?
Thanks.
stuart_morgan_64 is offline
Old 7th Apr 2018, 6:57 pm   #2
ThePillenwerfer
ThePillenwerfer's Avatar
Default Re: Electronic microphone circuit.
I had the self-same problem and nothing I tried made any difference for good or ill. I then came up with the attached. It's also much simpler in general.
File Type: pdf Single Transistor Telephone Transmitter.pdf (100.7 KB, 214 views)
ThePillenwerfer is offline
Old 7th Apr 2018, 8:04 pm   #3
stuart_morgan_64
Thanks for that. PCB too and smaller. Had troubles fitting mine in some of the Belgian phones. Will give that a go tomorrow. Thank you.
Old 7th Apr 2018, 8:06 pm   #4
stuart_morgan_64
I was thinking of making it surface mount.
Old 8th Apr 2018, 9:51 am   #5
ThePillenwerfer
SMT is beyond my skills and eye-sight but I can certainly see the advantage. I've made them 'dead-bug' style and put them in old No 13 transmitters. The smaller round board fits inside a No 16.
I attach the PCB artwork in PNG format as that'll be easier to work with/amend as needed.
Old 8th Apr 2018, 10:36 am   #6
paulsherwin
paulsherwin's Avatar
Just in case anybody doesn't realise, you don't actually need to use a BC337 with that circuit if you don't have one handy. Any of the common general purpose types should be fine.
paulsherwin is offline
Old 8th Apr 2018, 11:04 am   #7
ThePillenwerfer
Indeed, Paul. It was you who put me onto BC337s and BC327s instead on BC548s &c.
Old 8th Apr 2018, 1:37 pm   #8
stuart_morgan_64
Thanks for all the comments. I understand the transistor isn't too critical. Square would be easier to cut. I use a electric tile cutter for PCB.To cut round I use fret saw, blades dont last too long though. Not very neat either.
I will try some of your design in the next few days.
