Old 16th Nov 2014, 4:17 pm   #21
ms660
ms660's Avatar
Default Re: Cutting aluminium chassis with a Dremel
I agree, also you can usually clamp a straight edge to the job if it's a straight cut to act as a guide for the jigsaw's sole plate.
Lawrence.
ms660 is offline
Old 16th Nov 2014, 7:15 pm   #22
dseymo1
I must be doing something wrong.
Despite the soleplate following a straightedge, I find that the blade still wanders.
What's the trick?
dseymo1 is offline
Old 16th Nov 2014, 7:30 pm   #23
Steve_Bell
I tried a diamond cutting wheel on a scrap piece of aluminium but was unimpressed with the results.
I just used a fine toothed blade in a coping saw in the end.
Steve_Bell is offline
Old 16th Nov 2014, 8:44 pm   #24
mole42uk
mole42uk's Avatar
Originally Posted by dseymo1 View Post
What's the trick?
Possibly pushing the blade into the work. You really just have to gently push the saw enough to allow it to keep up with the cut, not the other way around.
Alternatively you could have a slightly off sharp blade, or not coarse enough (too many tpi) or the blade isn't fixed properly in the saw.
Richard
Index:
mole42uk is offline
Old 16th Nov 2014, 9:05 pm   #25
ms660
ms660's Avatar
Also some metal cutting jigsaws have a shorter stroke:
http://www.bosch-professional.com/gb...l-26175-ocs-p/
Lawrence.
ms660 is offline
Old 16th Nov 2014, 10:05 pm   #26
David G4EBT
David G4EBT's Avatar
We have to work with the tools that we've got, but I think that in general, pendulum action jigsaws - whatever the material that they're cutting, work better than basic ones. The pendulum action helps sawdust/metal swarf clear from the blade, and aluminium is the very devil for clogging the teeth saws and files. This (promo) video explains the importance and benefits of pendulum action:
http://www.toolstop.co.uk/the-import...-have-it-a1119
This video by the 'Ultimate Handyman' website shows how to cut sheet metal (steel in this case) with a jigsaw and gives some useful tips, but though steel is much harder than aluminium, it does cut better as unlike aluminium, steel doesn't 'pick up' on the teeth:
https://www.youtube.com/watch?v=fWpHzf1I0BI
Personally, for cutting holes of any size I always drill a series of holes adjacent to each other all the way round the perimeter, close to the cutting line, then I remove the scrap and use files to clean up the edges. For cutting sheet, I used a hand hacksaw.
Good luck in your endeavours.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 19th Dec 2014, 8:59 am   #27
Variometer
I used to cut aluminium sheet by simply scoring each side with a scalpel and then bending it slightly from side to side until metal fatigue broke it.
Nowadays, I invariably cut it with a small hobby bandsaw. At first, I feared it might blunt the blade, but it seems to have little effect, and I even think it improves the blade. After I gained confidence, I began cutting sheet brass with the bandsaw as well. I always wear goggles when cutting, but have never had any problems with it jamming or throwing slivers of metal out!
Bob
Variometer is offline
Old 19th Dec 2014, 2:44 pm   #28
elanman99
elanman99's Avatar
What's the trick?
To get a straight line when following a fence the first thing you need is a good quality jigsaw, next, a good quality blade with teeth that cut equally on both sides. Thirdly go slowly and don't force the blade. I have used an early Bosch pendulum Jigsaw for over 30 years and cut every thickness of all materials know to man! (lopped branches about 5" diameter! 6mm thick SS, 10mm thick aluminium etc)
One tip if you want to preserve a painted or anodised finish is to do all the marking out on a piece of hardboard or thick cardboard, thin (3mm) MDF is perfect. There are two (three really) massive advantages to sandwiching a sacrificial template, firstly the sawdust is a brilliantly effective 'lubricant' and stops the teeth clogging especially on aluminium but it works well on steel and even plastic. Secondly swarf does not get under the jigsaw soleplate and then hammered by vibration into the work surface, that applies even if you are cutting from the side that only you might see. Lastly wood or whatever is easier to do the marking out on.
Ian
a Two things I do when cutting metal with a jigsaw
elanman99 is offline
