Old 17th Jan 2011, 11:28 pm   #21
Steve_P
Steve_P's Avatar
Default Re: Philips B3X85U troubleshooting
Fine. Not a problem there. What do you get at the other side of it?
Cheers,
Steve P.
Steve_P is offline
Old 17th Jan 2011, 11:48 pm   #22
Abraham
It measures 00.0 also
Abraham is offline
Old 17th Jan 2011, 11:53 pm   #23
Steve_P
Steve_P's Avatar
Right. There should be a voltage here. The next valve back is a UABC80.
http://www.r-type.org/exhib/aaa0171.htm
There should be a voltage on Pin 9. I suspect there isn't. There is a resistor between here and the HT line. If there is voltage on the other end of this resistor, then check the wiring and then change this resistor.
Cheers,
Steve P.
Steve_P is offline
Old 17th Jan 2011, 11:56 pm   #24
Abraham
should I re-solder the capacitor before taking the reading?
Abraham is offline
Old 17th Jan 2011, 11:57 pm   #25
Steve_P
Steve_P's Avatar
Yeah, you might as well.
Cheers,
Steve P.
Steve_P is offline
Old 18th Jan 2011, 12:23 am   #26
Abraham
Don't know if I mistakenly disconnected the wrong capacitor. It was connected to Pin #2 of the UBC81
Abraham is offline
Old 18th Jan 2011, 12:32 am   #27
Abraham
The valves on the radio are: B1- UCH81, B2 - UF89, B3 - UBC81, B4 UL84, B5 - UY41, B6 - UM80
Abraham is offline
Old 18th Jan 2011, 12:33 am   #28
Steve_P
Steve_P's Avatar
Yes. By the way it does not have a UABC80. My mistake. It has a UBC81 instead.
http://www.r-type.org/exhib/aaa0478.htm
The capacitor you want goes between Pin 1 of this valve and Pin 2 of the UL84. There should be nothing on Pin 2 of the UL84. The other side of this capacitor should go to Pin 1 of the UBC81. There should be a voltage here, if not the same applies, trace it back to the HT line.
The cap on Pin 2 of the UCL81 is the wrong on.
Cheers,
Steve P.
Steve_P is offline
Old 18th Jan 2011, 12:36 am   #29
Abraham
Here's a pic of the capacitor I disconnected.
Abraham is offline
Old 18th Jan 2011, 1:02 am   #30
Abraham
Also what does HT stand for
Abraham is offline
Old 18th Jan 2011, 1:11 am   #31
AlanBeckett
Literally High Tension.
B+ in American.
Alan
AlanBeckett is offline
Old 18th Jan 2011, 1:14 am   #32
Abraham
On the cap, which I disconnected and goes from Pin #2 of the UBC81 to Pin #1 of the UL84 by means of a jumper wire and resistor. On the side that it is supposed to go to Pin #1 of the UBC81, it does not have a reading. Nor does the side that has the jumper wire that connects to the resistor, does not give any reading at all. (no voltage).
Abraham is offline
Old 18th Jan 2011, 1:17 am   #33
Station X
Station X's Avatar
HT stands for High Tension meaning high voltage.
It's difficult to tell from the picture which capacitor you've disconnected. Reconnect it and then recheck the voltage between Chassis and pin #2 of the UL84. In post #15 you said it read +4.4V which indicates a fault condition. If you still have a positive voltage on pin #2 of the UL84 disconnect the capacitor from pin #2 and check the voltage there again. If it's now zero this indicates that the capacitor is faulty.
Report your findings.
EDIT. We posted together. You've disconnected the wrong capacitor. Reconnect it and test as above.
Graham. Forum Moderator
Station X is online now
Old 19th Jan 2011, 12:22 am   #34
Abraham
The cap that I had disconnected was the one that goes to Pin #1 of UBC81 and disconnected it measures 0.0 On the side of the cap that goes to Pin #2 of the UL84, it measures 2.2.
Other than that, on the UL84, measurements of
Pin #2 is 0.25mv DCV (Control Grid)
Pin #9 is 99V DCV (Screen Grid)
Pin #7 is 115v DCV (Anode)
Pin #3 is 5.23v DCV (Cathode)
Pin #5 is 94.5V ACV
Pin #4 is 49.0 ACV
On the UBC81, measurements are
Pin #1 - 0.63mv DCV (Anode)
Pin #2 - 0.82v DCV (Control grid)
All this was done with the cap disconnected from Pin #1 of the UBC81
Thanks again
Abraham is offline
Old 19th Jan 2011, 12:30 am   #35
Steve_P
Steve_P's Avatar
There should be more than that on Pin 1 of the UBC81. Check this again and check the resistor that should go between here and the HT line. Check the wiring and if there is voltage on the other side of this resistor, change it.
If not, go back until you do find HT.
Cheers,
Steve P.
Steve_P is offline
Old 19th Jan 2011, 2:07 am   #36
Station X
Station X's Avatar
If both measurements were taken with the cap disconected from pin #2 of the UL84, then the capacitor is faulty.
Old 19th Jan 2011, 4:46 am   #37
Abraham
I checked again now with the cap soldered on to Pin #1 and it fluctuates from 4.5 to 5.0mv on Pin #1.
can I replace the cap with the same 10Nf but instead of a 1000vcc, it is 250v?
Abraham is offline
Old 19th Jan 2011, 12:01 pm   #38
Station X
Station X's Avatar
Let's do this one step at a time.
Before you replace the capacitor you need to find out why you don't have HT voltage on pin #1 of the UBC1.
Follow Steve's instructions in post #35.
Old 19th Jan 2011, 12:34 pm   #39
Hunts smoothing bomb
Hunts smoothing bomb's Avatar
Hi all,
I don't know this set but does anyone know if it has a mains transformer? If not is the HT about right as the mains voltage supply in Panama City according to this link http://www.kropla.com/electric2.htm is 120vac 60Hz.
In an earlier post a resistance value of 1748 ohms was quoted but I couldn't make out where exactly it was measured from, could you be more specific Abraham as to where your probes were when you took this reading?
Lee
Lee
Hunts smoothing bomb is offline
Old 19th Jan 2011, 12:53 pm   #40
Station X
Station X's Avatar
Here's an extract from the service manual.
THAT capacitor is C29. It doesn't go directly to UL84 pin #2, but goes via resistor R21.
The most likely cause for no HT on the UBC81 is R15 being high value or open circuit.
With no power applied check its value with you meter on ohms range. Replace if more than 20% off value.
With power applied measure the voltage from chassis to both sides of R15.
Report back here. There are several of us here keen to see this radio working.
