Old 21st Dec 2009, 12:17 am   #121
oldticktock
Default Re: Newb Stumped on a Derwent
6v between 4 & 5
the other end of the resistor went to pin 4 of the 42
oldticktock is offline
Old 21st Dec 2009, 12:20 am   #122
Steve_P
Steve_P's Avatar
Question - is there a resistor between Pin 4 and Chassis right now. Yes or no?
Cheers,
Steve P.
Steve_P is offline
Old 21st Dec 2009, 12:25 am   #123
oldticktock
Cheers,
Steve P.
yes
Old 21st Dec 2009, 12:26 am   #124
electrogram
Originally Posted by Station X View Post
Steve P.
[The 75 is a triode and two diodes in the same envelope. They have a common cathode. Therefore the cathode current of all four valves (42 and 75) will flow through the cathode resistor. I'm wondering if it should be a lower value than 500ohms? It might be a body, tip spot type of 450 ohms. ] ]
Post 87 says 75 has its own bias resistor of 5000 ohms
electrogram is offline
Old 21st Dec 2009, 12:27 am   #125
Steve_P
Steve_P's Avatar
Does it measure OK? 500 Kohms or so?
Cheers,
Steve P.
Steve_P is offline
Old 21st Dec 2009, 12:28 am   #126
oldticktock
510k to be exact or 510,000
Old 21st Dec 2009, 12:30 am   #127
Steve_P
Steve_P's Avatar
Fine. Have you got a scope I wonder?
Cheers,
Steve P.
Steve_P is offline
Old 21st Dec 2009, 12:32 am   #128
Station X
Station X's Avatar
It actually says he measured 5000 ohms, which isn't the same thing. Also the drawings show the cathodes of the 42 and the 75 connected together. It doesn't look right to me, but that's how it is.
Graham. Forum Moderator
Station X is online now
Old 21st Dec 2009, 12:35 am   #129
Station X
Station X's Avatar
6v between 4 & 5
That's low, it should be the same as the cathode voltage ie 23V. Is THAT capacitor disconnected? If not measure again with THAT capacitor disconnected. Get rid of the surplus 510K resistor too.
Old 21st Dec 2009, 12:35 am   #130
oldticktock
Cheers,
Steve P.
I have a solatron ct160 but believe me that was bought with the intention of using when i'm grown up. also not been powered up for 3 years so will need to do so slowly on the variac
Old 21st Dec 2009, 12:39 am   #131
oldticktock
hmm
Old 21st Dec 2009, 12:40 am   #132
Steve_P
Steve_P's Avatar
Pity. We could have looked for the Audio.
It's unlikely that THAT capacitor is faulty, but it happened to me once, so it's possible.
Cheers,
Steve P.
Steve_P is offline
Old 21st Dec 2009, 12:45 am   #133
oldticktock
Cheers,
Steve P.
your up for giving me pain arn't you ....... can you imagine numpty boy and an oscilloscope. I bought a book "Understanding oscilloscopes and display waveforms", these guys are mad!!!
Old 21st Dec 2009, 12:47 am   #134
Sean Williams
Sean Williams's Avatar
Im really wondering if we could have a piccy of the whole underside of the chassis - this is just an overgrown US midget set, so really shouldn't present this much trouble getting the audio stage to work reliably!
I also think we need to standardise on some terminology here.....
Sean Williams is offline
Old 21st Dec 2009, 12:49 am   #135
Steve_P
Steve_P's Avatar
He's right, we should. But, looking at the picture that OTT drew, I would like to disconnect the tone control and try it.
Cheers,
Steve P.
Steve_P is offline
Old 21st Dec 2009, 12:49 am   #136
oldticktock
Underside already posted not sure how far back probably page 4,5 or 6. On the main holding (domestic) you can see all the attachments i thin its "derchas"
Old 21st Dec 2009, 12:51 am   #137
oldticktock
a photo was taken here it is again
Oops it won't let me load same one anyway its not correct now as the 50uf is back in place the right way round.
Old 21st Dec 2009, 1:01 am   #138
electrogram
Are you saying cathode current of 42 passes through both 470 and the 'measured' 5000, but in that case the 510k on pin 4 of 42 might better be returned to junction of the two resisrors the 540 and 5000, that is pin 5 cathode pin of 75, therefore the only error in post 53 is that 510k was connected to pin 5 not 4 of 42
Old 21st Dec 2009, 1:11 am   #139
oldticktock
6v between 4 & 5
as requested and 23v is the result
Old 21st Dec 2009, 1:22 am   #140
Station X
Station X's Avatar
So with THAT capacitor connected you get 6V between pins 4 and 5 of the 42, and with that capacitor disconnected you get 23V between pins 4 and 5?
If that's the case then THAT capacitor is faulty.
