Old 21st Aug 2019, 8:25 pm   #1
FERNSEH
FERNSEH's Avatar
Default Riviera Radio set.
Arrived today a radio set made by Riviera Radio. I know nothing about the firm that made the set except the electronics resemble the battery version of the KB Pup. That is, a very simple circuit employing two triode valves. Only one tuned circuit for medium and long wavebands. The reaction control functions as the volume control.
As the attachment shows there isn't much scope of improving the set other than constructing an entirely chassis using better valves. In it's present state the choice of valves is limited by the four pin sockets.
I bought the set because I liked the look of it.
DFWB.
ID:	188690   Click image for larger version
ID:	188691   Click image for larger version
FERNSEH is offline
Old 21st Aug 2019, 8:47 pm   #2
ms660
ms660's Avatar
Default Re: Riviera Radio set.
https://www.bvws.org.uk/publications...letin_10_1.pdf
Lawrence.
ms660 is offline
Old 21st Aug 2019, 9:02 pm   #3
FERNSEH
FERNSEH's Avatar
Hi Lawrence,
many thanks for your research. Like certain KB models the set was acquired by cigarette coupons.
So apart from the missing loudspeaker which I can do nothing about except fit a modern PM unit the set should be restored to it's original state.
DFWB.
FERNSEH is offline
Old 21st Aug 2019, 9:02 pm   #4
trabant
At the price it went for there wasn't enough of it left to warrant me bidding lol
trabant is offline
Old 22nd Aug 2019, 9:21 am   #5
Tractionist
Originally Posted by FERNSEH View Post
Hi Lawrence,
DFWB.
Hi David - Lawrence is spot-on [as usual!] .... I was going to mention the apparent absence of the speaker and the similarity to certain EKCO cases/cabinets [also referred to in the BVWS article]. I wonder who actually did make the case ..... E.K. Cole?
These 'Cigarette Coupon' sets seem to be very rare .... perhaps because their owners [and secondary inhalers] checked-out prematurely! When I was in the BVWS [early days] I seem to recall an article regarding the restoration of a very rare 'Kensitas' [mains-powered with selenium rectifier] 'Coupon Set' too.
I wonder in what sort of quantities these things were manufactured?
let us know how you get on eh?
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 22nd Aug 2019, 10:43 am   #6
ronbryan
Are those solid dielectric variable capacitors labelled 'Igranic'? I have one here just like them - the profile is quite different to the usual Jackson Bros 'Dilecon' type.
Ron
ronbryan is online now
Old 22nd Aug 2019, 1:28 pm   #7
FERNSEH
FERNSEH's Avatar
"I wonder in what sort of quantities these things were manufactured?"
Hi Tractionist, I'd say tens of thousands and that means of course tens of thousands smokers. What an awful way to acquire a radio set.
Hi Ron, there's no makers name on the tuning and reaction capacitors, or should we call them condensers.
The coupling transformer has an open circuit secondary.
DFWB.
FERNSEH is offline
Old 22nd Aug 2019, 5:37 pm   #8
PJL
The moving iron part seems to be present so it is just missing the paper cone. I have rewound a couple of these recently and they were pretty easy to do.
PJL is offline
Old 22nd Aug 2019, 6:48 pm   #9
Heatercathodeshort
Heatercathodeshort's Avatar
They sound so much better if you can make the cone from a thin sheet of Polystyrene of the kind used to make paper cups, burger boxes etc. Even a drinks cup made of the same material gives good results! John.
Heatercathodeshort is offline
Old 1st Sep 2019, 6:56 pm   #10
trabant
Is this set based on the British Radiophone 2 valve sets ?
trabant is offline
Old 2nd Sep 2019, 11:21 am   #11
FERNSEH
FERNSEH's Avatar
Hi Trabant,
Was British Radiophone was a brand name used by the Plessey company?
Extract from Graces guide: 1922 Byron Clark seems to have been connected to Norman De Maid Watsham and A. H. S. MacCallum who founded British Radiophone Ltd. Watshams won an order from Marconi for 2 types of crystal set and a valve receiver[3]; it is unclear what role]British Radiophone Ltd played in this order but the order for crystal sets was sub-contracted to Plessey Co. This was the start of Plessey’s diversification into radio and electronic manufacturing.
From Graces Guide:
https://www.gracesguide.co.uk/Plessey_Co
DFWB.
FERNSEH is offline
Old 2nd Sep 2019, 8:08 pm   #12
AC/HL
AC/HL's Avatar
Two OT posts deleted.
AC/HL is offline
