Old 27th Jul 2019, 9:08 pm   #1
Julesomega
Julesomega's Avatar
Default Using LibreCAD
Has anyone here used LibreCAD for simple engineering drawings? I want to get a local engineer to make some simple mechanical parts and I was hoping to produce drawings in LC and I am trying follow the steps in the basic mechanics tutorial but having told you to use snapping to the grid to avoid tediously entering every coordinate by hand it has nothing to say about how you select the grid size to snap to. Neither does anywhere in the online user manual. There is a forum for users, none of whom seem to use the software, they all seem to be developers explaining how they've improved the functions.
I'll start drawing the parts with a pencil, but it would be rather nice to be able to use the s/w
- Julian
It's good here
Julesomega is offline
Old 27th Jul 2019, 11:37 pm   #2
joebog1
Default Re: Using LibreCAD
Its my program of choice. Very easy to drive and has hundreds of extra libraries available online. To change the grid size you will have to go to preferences and look for "GRID". its in the same are as where selecting imperial or metric measurements are selected.
I use it mostly for chassis layouts though, not machine drawings, although they should be very similar. I use Linux however and have no idea what Windows does to the program.
I can take screen shots of the setup for grid spacing if you need, just ask.
Joe
joebog1 is offline
Old 27th Jul 2019, 11:58 pm   #3
Bazz4CQJ
Bazz4CQJ's Avatar
I've never used LibreCad, as Lotus Freelance generally meets my requirements. In that, you'd go to VIEW and the drop down box then offers "Set Units and Grid" and clicking on that opens all the boxes for the various settings.
B
Bazz4CQJ is offline
Old 28th Jul 2019, 12:15 am   #4
Herald1360
Herald1360's Avatar
I've just downloaded it and had a bit of a play- as far as I can see, you select your units (inches, millimeters (sic), feet etc) in Options/Application Preferences/Defaults then go to Options/Application Preferences/Appearance and type in the minimal grid spacing you want. As far as I can tell, 1px gives a grid in base units, 10px a grid in tens of base units etc.
I couldn't find anything helpful in the Help wiki either....
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 28th Jul 2019, 6:01 am   #5
joebog1
start Librecad,
open the "EDIT" menu,
open the preferences menu
select your drawing preferences.
The "GRID" setting will be automatically set to "AUTO",
so if your drawing is in millimetres the grid will be set to millimetres.
The actual amount of millimetres can be set to
.01
.1
1
10
base units, so in millimetres its very obvious that selection 3, or 1,
is 1 mm grid graduations.
Joe
joebog1 is offline
Old 28th Jul 2019, 12:46 pm   #6
Uncle Bulgaria
Uncle Bulgaria's Avatar
I use Draftsight for my architectural work. Alas, the free edition is coming to an end this December, but until then it's been a very capable CAD programme. Many of these are AutoCAD clones from earlier versions, so it's sometimes helpful to try to do things as they would be done in AutoCAD.
Does LibreCAD have snapping to points you have drawn included? For example can you draw a line, then have your next point snapped to the vertical line through that point, at a specified distance? I find the best way to use CAD is to reference all points to a previous one or two, so the object is built up with geometric references.
As Joe mentions the preferences, something to check is that the model scale is set correctly (1:1) and that you aren't accidentally drawing at a paper scale which will get confusing when it comes to fabrication.
Apologies if this is grandma and eggs territory. I haven't used this particular programme, though I did investigate it a couple of years ago before going with Draftsight. However, in my experience they have points of convergence as there are only so many ways to place lines on a screen!
Uncle Bulgaria is offline
Old 28th Jul 2019, 2:35 pm   #7
Julesomega
Julesomega's Avatar
Thanks for all answers. Maybe it's the new version 2.1.3 but there are no options for snap. I can only snap to the grid. I want to snap to the nearest 1mm while showing a 10mm grid, seems a reasonable expectation. I attach screenshots of the drop-down menus: note that the settings are under a new menu 'Options' rather than under 'Edit'
Name:	LibreCAD Options menu.jpg
ID:	187474   Click image for larger version
Name:	LibreCAD Edit menu.jpg
ID:	187475   Click image for larger version
Name:	LibreCAD Application Prefernces.jpg
ID:	187476   Click image for larger version
Name:	LibreCAD Drawing Prefernces.jpg
- Julian
It's good here
Old 28th Jul 2019, 11:55 pm   #8
joebog1
I have a whole library of things I can do with "SNAP".
Free Snap
Snap on Grid
Snap on End Points
Snap on Entity
Snap on Centres
Snap Middle
Snap Distance
Snap intersection
Restrict Horizontal
Restrict Vertical
Restrict Orthogonal
Restrict Nothing
Set Relative Zero Position
Lock Relative Zero Position
This might not help much if its not easily visible!!
I DID explain I run Linux!!
My version of LibreCad was compiled in 2016 so its not such a new version,
( it is the current version however) but in the time I have been using it
( ~15 years) it has not really changed that much. LibreCad started as QCad, and split off when QCad went commercial. There is documentation online for using QCad and I have a full copy "somewhere". I will try and find it for you.
I hope this helps,
Joe
Name:	Screenshot from 2019-07-29 08-37-27.png
ID:	187497   Click image for larger version
Name:	Screenshot from 2019-07-29 08-46-23.png
joebog1 is offline
Old 29th Jul 2019, 12:12 am   #9
joebog1
This site will help you I think
https://qcad.org/en/documentation
Joe
joebog1 is offline
Old 29th Jul 2019, 11:40 am   #10
joebog1
I cant help with windows
I know absolutely nothing about it.
My apologies for wasting your time
Joe
joebog1 is offline
Old 29th Jul 2019, 11:53 am   #11
Julesomega
Julesomega's Avatar
It looks like I need to install an earlier version of LibreCAD, pity oldapps.com does not have any. I took a look at Qcad which looks comparable and has a free 'coomunity' unrestricted version but looking at the documentation shows among the myriad snap options it will only snap to the grid. Does anyone have an install file?
I wonder if a W98 version of AutoSketch would run under W10? I still have it on a floppy - less than 720KB and absolutely no bloatware! I used to use it for every kind of drawing including mechanical and schematics
- Julian
It's good here
Old 29th Jul 2019, 12:05 pm   #12
Trigon.
Trigon.'s Avatar
For anyone who's used an Autodesk product (or clone) then, yes, that seems a perfectly normal and essential function. Apparently if you haven't, it's a strange concept and inconceivable that anyone would want to do such a thing!
Cheers!
Trigon. is offline
Old 29th Jul 2019, 12:13 pm   #13
Julesomega
Julesomega's Avatar
Phew, so it's not just me
- Julian
It's good here
Old 29th Jul 2019, 4:51 pm   #14
Marconi_MPT4
Marconi_MPT4's Avatar
It looks like I need to install an earlier version of LibreCAD...
Earlier released versions and patch updates of LibreCAD can be found here at GitHub
https://github.com/LibreCAD/LibreCAD/releases
Rich
To an optimist a glass is half full; a pessimist half empty; an engineer twice as big as need be!
Marconi_MPT4 is online now
Old 4th Aug 2019, 4:58 pm   #15
Julesomega
Julesomega's Avatar
I guess I was in too much of a hurry when I first asked, I was trying to do the job. Now that's out of the way I've gone back and looked at LibreCAD and it now snaps happily to the required 1/10th of the grid.
My "current drawing preferences" are set to:
Units > main drawing unit - mm, precision - 0.0
Grid - show grid, X & Y spacing 0.1
The snap points within the grid are shown by dots.
As someone used to say (Phil?) "Don't let anything digital know you're in a hurry"
- Julian
It's good here
Old 4th Aug 2019, 11:33 pm   #16
joebog1
I'm glad you got it sorted. Once you learn the basics it's very fast, produces superb drawings, even on a cheap printer.
I'm still looking for the CD of instructions. I haven't forgotten you
Joe
joebog1 is offline
