Old 17th Apr 2019, 1:08 pm   #21
Miguel Lopez
Miguel Lopez's Avatar
Default Re: Building a little practical audio amplifier for experimentation
Originally Posted by Andy
what are those trimmer pots for?
To adjust the center "tap" of the heaters, both on the amplifier and rectifier valves, to reduce hum
are you still using aspirin as flux?
I am. But those soldering that you see on the PCB were done using the solder that you once sent me. That's why it looks shinning. That solder is reserved for important projects only.
Originally Posted by David
use insulating 'top hat' bushes on the screws.
I will use insulating sleeves and bakelite or fiberglass washers.
When electrons move, things happen.
There's nothing you can do that can't be done.
Miguel Lopez is offline
Old 13th May 2019, 5:56 pm   #22
Miguel Lopez
As Mr Time, the "Implacable", has no mercy of this humble mortal, I'm advancing very slow with this project, as usual. Anyway I have done some advances that I want to share with you. It is already working althought I have not tested it with audio nor a speaker, just a 1kHz signal from my signal generator. The sine wave was clean for a power of about 3W, which is more than enough for what I want. I powered a 10 ohms dummy load.
ID:	183010   Click image for larger version
ID:	183011   Click image for larger version
ID:	183012   Click image for larger version
ID:	183013   Click image for larger version
Old 13th May 2019, 9:02 pm   #23
Sideband
Sideband's Avatar
That is a very impressive construction method....looks like a piece of restored military kit! Well done!
Sideband is offline
Old 18th May 2019, 7:56 pm   #24
Skywave
Question Re: Building a little practical audio amplifier for experimentation
I'm probably mistaken about this, but looking at R9, the phasing connections of the O/P transformer and the grid-anode phase relationships of the valves, isn't that feedback via R9 in-phase with any signal appearing on the grid of the first triode - thus increasing the chance of instability?
Al.
Skywave is offline
Old 18th May 2019, 11:17 pm   #25
Paul JD
The feedback is going to the cathode of the input stage so it needs to be in phase with the signal on the grid in order to produce negative feedback.
Paul JD is offline
Old 5th Jul 2019, 3:26 pm   #26
Miguel Lopez
I'm advancing very slow on this project due to lack of available time. Anyway I have begun to build the input block with the three different plugs, which will be connected in "star".
ID:	186212   Click image for larger version
Old 30th Jul 2019, 9:31 pm   #27
Miguel Lopez
On last weekend I did some advances on this project. I mounted the shield between the transformers and the signal lines (input conectors and volume potentiometer), and also put the input connectors on their place. I played music with the amp for the whole weekend althought it is not finished yet. I have to build the front panel and the built-in speaker cabinet. See some pictures
ID:	187593   Click image for larger version
ID:	187594   Click image for larger version
Old 23rd Sep 2019, 2:44 pm   #28
Miguel Lopez
This weekend I was able to resume working on this little project. Mr Time the "implacable" has been implacable with me but now I have been able to go on with this. I built the rest of the chassis, but I wasn't able to built the built-in speaker cabinet as the speaker that I have is too big, and there is no roon inside the chassis. I will go to my "war reserve" to find a flatter speaker to fit inside. Anyway I used it this way on weekend.
ID:	190703   Click image for larger version
Old 8th Oct 2019, 2:55 pm   #29
Miguel Lopez
Finally I found a suitable speaker and I fitted it inside the amplifier. It's from an old Soviet TV.
Old 11th Oct 2019, 4:45 pm   #30
Miguel Lopez
Yesterday I used this amplifier the whole day. It worked nicely, and it's now fully operational
Old 11th Oct 2019, 5:39 pm   #31
Diabolical Artificer
Diabolical Artificer's Avatar
Good work mate, hope you have some brighter paint to paint than your usual battle ship grey or 70's nylon shirt brown : ) A nice bright orange would look well.
Andy.
Old 11th Oct 2019, 8:47 pm   #32
Miguel Lopez
A phosphorescent pink or violet would be nice too, don't you think?
Old 12th Oct 2019, 2:22 am   #33
joebog1
I must say Miguel, you do make a beautiful job. I must agree with Andy however
Soviet grey can be a bit over whelming. Superb job however.
Did the 807 and valve base come in handy ?
Best regards
Joe
joebog1 is offline
Old 12th Oct 2019, 4:27 pm   #34
usradcoll1
Andy.
Things are probably a bit different in Cuba!
Ours and your home improvement stores have just about any color paint in any finish you desire. Possibly, not the same there.
Fine job done there. Too bad you couldn't fit a larger speaker To do justice to the EL84 output valve and the larger output transformer.
Dave, USradcoll1, always interested!
usradcoll1 is offline
Old 14th Oct 2019, 12:18 am   #35
retailer
Good job I'm sure you are pleased - while grey may not be the brightest colour around, paint, no matter the colour always improves the look of a project.
retailer is offline
Old 14th Oct 2019, 2:05 am   #36
fetteler
fetteler's Avatar
Miguel,
Please do not pay any attention to those who would make trivial comments about "Soviet" paint colours. One does not judge a book by its cover.
Your amplifier build is superb and I am sure you will have many happy hours listening to it.
Best wishes,
Steve.
Those who lack imagination cannot imagine what is lacking...
fetteler is offline
Old 14th Oct 2019, 9:20 am   #37
alanworland
alanworland's Avatar
Miguel, trust you and yours are well.
Your amplifier looks superb and I am sure it will stand you well for all of its up and coming projects! Most test amplifiers I am sure remain at no more than a breadboard stage of assembly and get used that way for years.
Yours is a proper build.
(I'd be tempted to leave it unpainted!!)
Alan
alanworland is offline
Old 14th Oct 2019, 9:50 am   #38
PJC58-Hythe
PJC58-Hythe's Avatar
Miguel,
Really nice to see proper 'homebrew' equipment, you have done an excellent job and should be proud of it!
All the best, and keep up the constructing!
Peter - M0HYT - BVWS Member - GQRP Club
http://www.retroworkshop.co.uk
PJC58-Hythe is offline
