Old 11th Aug 2014, 11:28 am   #101
Station X
Station X's Avatar
Default Re: Ambassador 545
Chocolate block is horrible stuff and best avoided. Some of the stuff supplied by DIY outlets comes with the threads already stripped. When used with stranded wire it's all too easy to cut through strands by over tightening. Leave the screw too loose and it may vibrate free releasing the wire . Terminating wires directly under screws has never seemed like a good idea to me. The connectors where some kind of metal barrier is interposed between the wire and the screw are much better.
In a vintage radio it's much better to solder the mains lead.
Graham. Forum Moderator
Station X is offline
Old 11th Aug 2014, 11:48 am   #102
stevehertz
stevehertz's Avatar
Originally Posted by G6Tanuki View Post
If you want to neaten up stranded wire before fitting to a screw-terminal, crimp on a "bootlace ferrule"
Probably a brand or makers name, but in my Thorn days they were known as mischke terminals. Not sure about the spelling there, but I think during my time in 'stock control' and 'buying', that was how I saw the word typed out.
stevehertz is offline
Old 11th Aug 2014, 5:40 pm   #103
sooperrio
Thanks everyone, quite a bit for me to digest here, so I will take my time with all your comments.
sooperrio is offline
Old 12th Aug 2014, 12:12 pm   #104
sooperrio
Just reading this websites advice on cabinet care, and I noticed it states do not use Pledge or Mr Sheen to polish the wood.
May I ask why?
Old 12th Aug 2014, 1:03 pm   #105
stevehertz
stevehertz's Avatar
Being silicone based, they are more for use on plastics and such finishes on modern items. Older wireless sets are perhaps better polished and cleaned using a more 'wood friendly', natural product.
Old 12th Aug 2014, 2:20 pm   #106
sooperrio
Thank you, Steve.
Old 24th Aug 2014, 9:02 am   #107
sooperrio
Another really silly question, but I need to ask because I am struggling!
Do valves ALWAYS glow if operating correctly?
I have one that isn't and I daren't leave the set on for more than a few seconds for fear of blowing something.
PS - When you guys talk about "heaters" on this forum, are you referring to a part of a valve that glows?
Old 24th Aug 2014, 9:54 am   #108
Michael.N.
Originally Posted by sooperrio View Post
May I ask why?
Use spit (ugghh!). A wonderful and extremely gentle cleaner. So good that museum conservators have been known to use it.
Liberon burnishing cream is a finish reviver. It contains a very fine abrasive (some sort of very fine Rottenstone/Tripoli powder) suspended in a solvent. I've never found it to be a problem with Shellac. Don't use it more than once, it's still an abrasive (however gentle) and eventually you will end up with a finish that looks like glass (ugghh! again).
A little White Spirit on a cloth is pretty effective at removing dirt and grime. You can use a simple furniture wax after.
Michael.N. is offline
Old 24th Aug 2014, 9:58 am   #109
sooperrio
"Spit"?? Really!?
Well, I suppose if it's good enough for the army's boots!
Spit and polish
Will buy the Liberon cream, I think I have some of their other products.
Thanks!
Old 24th Aug 2014, 10:13 am   #110
Station X
Station X's Avatar
Yes the heater is the part of the valve which glows. Its purpose is to heat the cathode electrode so that it emits electrons.
All valves glow to some extent, but some glow so dimly that it may only be possible to see the glow in the dark and then only if you're looking at the right angle.
You can test a valve's heater by measuring the resistance between the heater pins. An infinite (open circuit) reading indicates a faulty (blown) heater. Do this test with the valve removed from the circuit or you'll get a false reading.
The heater pins for each valve are clearly shown on the ERT Service Sheet.
Old 24th Aug 2014, 10:15 am   #111
sooperrio
Thank you, Graham!
Old 25th Aug 2014, 9:29 am   #112
sooperrio
Graham,
The valve was open circuit, so thanks for your help, am now on the hunt for a replacement.
Much appreciated.
Old 25th Aug 2014, 10:04 am   #113
stevehertz
stevehertz's Avatar
What valve is it? Not sure if you've already done it, but there's a 'wanted' page on this forum.
Old 25th Aug 2014, 11:24 am   #114
sooperrio
Hi Steve
It's a Pen45, haven't seen the 'wanted' page, thanks for pointing me in the right direction!
Old 25th Aug 2014, 8:08 pm   #115
stevehertz
stevehertz's Avatar
Give it a go on the wanted page, it's not an uncommon valve, I may have one myself somewhere, but not saying that I can lay my hands on one easily as I have boxes of old valves to wade through. Anyway, see how you go on with a wanted ad.
Old 26th Aug 2014, 5:32 am   #116
sooperrio
Thanks, Steve, I will try that.
Old 16th Sep 2014, 12:37 pm   #117
sooperrio
Hello Everyone
Me again, asking for more help.
Please could somebody take a very quick look at the attached (very rough) drawing and confirm I have got the wiring correct for a lamp limiter?
Thanks in advance!
Gray
Name:	Lamp Limiter.jpg
Old 16th Sep 2014, 2:12 pm   #118
julie_m
Yes, that will work fine. Make sure the switch is open when you first connect it: closing the switch will short out the lamp and apply the full force of the mains to the appliance plugged into the socket. You probably will want to label the switch positions, to avoid potential disaster.
julie_m is offline
Old 16th Sep 2014, 4:38 pm   #119
sooperrio
Thank you, AJS, for your prompt reply!
Old 29th Sep 2014, 12:15 pm   #120
sooperrio
May I describe the results from my lamp limiter test, please?
I apply power from the mains, and the bulb filament glows orange, then fades, then after about ten - twenty seconds, the bulb filament glows again.
The light behind my radio tuning dial also lights.
Can I ask if this is good?!
More importantly, what is happening?
If anyone could explain really simply where the current is going, and what it is doing, I would appreciate it!
Thank you!
