Old 18th Dec 2018, 9:21 am   #1
CesarLG
CesarLG's Avatar
Default R1155 caps
Hello! I would like to replace the electrolytic caps as I always donon my old radios... but I see that R1155 doesn’t have any. Is that correct?
EA3IAV
CesarLG is offline
Old 18th Dec 2018, 9:30 am   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: R1155 caps
Yes I believe you are correct apart from main smoothing electrolytic s in a separate power supply,there are possibly one or two smaller biasing caps.
Note this is without looking.
HamishBoxer is offline
Old 18th Dec 2018, 9:58 am   #3
CesarLG
CesarLG's Avatar
Thanks! What about the voltage rating on the picofarad ones?
EA3IAV
CesarLG is offline
Old 18th Dec 2018, 10:09 am   #4
M0FYA Andy
No electrolytics in an R1155.
There are in the monster Air Ministry ground power supply, but that's another matter.
Andy
M0FYA Andy is offline
Old 18th Dec 2018, 2:56 pm   #5
AC/HL
AC/HL's Avatar
Unless there is a definite fault, it's not advisable to touch capacitors with low picofarad values. They're unlikely to be faulty, and are likely to disturb alignment.
AC/HL is offline
Old 18th Dec 2018, 4:28 pm   #6
cmjones01
My R1155 has (had) lots of metal-cased paper capacitors (branded TCC, I think) which look a bit like electrolytics. The ones in mine are hopelessly leaky, to the point of making fizzing bubbling noises due to electrolysis when HT was applied. They certainly needed replacing (I chose to restuff some because of their chassis mounting method) but they weren't electrolytic.
Chris
What's going on in the workshop? http://martin-jones.com/
cmjones01 is offline
Old 19th Dec 2018, 8:46 am   #7
CesarLG
CesarLG's Avatar
I have no problems with them I experience good reception and sound. But I think that the CW BFO setting is not performing at 100%... May it be due to that caps?
Where did you find that 2.5uf? I have just odered them but they are not easy to get
EA3IAV
CesarLG is offline
Old 19th Dec 2018, 9:43 am   #8
HamishBoxer
A 2.2uF is a perfect replacement for 2.5uF
Old 20th Dec 2018, 3:33 pm   #9
Keith
Keith's Avatar
As Chris says, the double and triple tubular decoupling capacitors are usually leaky and will degrade the performance of the receiver. I ended up restuffing mine with modern polypropylenes which should solve the problem long term.
ID:	174974   Click image for larger version
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is offline
