Old 17th Dec 2018, 1:16 pm   #1
Jaguar1964
Default Crypton Tuning Machine
Hi All
Let me start by apologising for this not being a radio topic and for it being written by an electronics novice
I recently bought an old Crypton Tuning machine from the 1960`s (I think) it's model No. BD120/FA6423 (this is a unit containing valves and a cathode ray tube)
Within this unit are two transformers and one of them is burnt out. The unit lights up and I would love to get it working to use on my old car
So here are my questions
1. Does anyone have a wiring diagram for this unit, or similar model/
2. Given it's burnt out could I tell the the transformer output voltages in any other way & seek a replacement? (input windings are 240V)
3. is it possible to get the transformer re-wound and if so what is the likely cost?
4. Do I have any other options?
All help will be gratefully received !!
Many thanks, Bijen
ID:	174789   Click image for larger version
Jaguar1964 is offline
Old 17th Dec 2018, 2:06 pm   #2
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Crypton Tuning Machine
Hello and welcome!
I used to use the model before that (round CRT)
1) I don't have a diagram
2) Tracing out the circuitry (it won't be terribly complex) will allow a reasonable guess at voltages.
3) yes, there are two people on here who regularly re-wind transformers and wind new ones.
4) It might be possible to count the turns while dismantling the old transformer and wind the new one from that.
Transformers are normally reliable beasts and just sit there inoffensively working. A burnt one may have a cause.
I think the EHT voltage for the CRT may be generated in a mains transformer. THese sorts of supplies can be quite dangerous if you are not very careful, and the high voltage winding might just be the site of insulation breakdown which starts the ball rolling. It may well have been killed by someone leaving it switched on overnight.
Discussion of electronic test gear seems admissible hereabouts, but you're best to steer clear of the things it got used on.
There should be an exhaust gas mixture meter under the roller door and a xenon strobe light.
Radio Wrangler is offline
Old 17th Dec 2018, 3:15 pm   #3
Jaguar1964
Thumbs up Re: Crypton Tuning Machine
Hi Radio Wrangler
Thanks for your reply
Mine also has a round CRT although it looks square on the front of the unit
I didn't realise it but I must be missing the exhaust gas mixture meter also I did think that the transformer failure may have an underlying cause but at least it's a start
Thanks again for the great advice, much appreciated !!!
Best regards, Bijen
Old 17th Dec 2018, 8:34 pm   #4
Ed_Dinning
Hi Bijen, I scrapped one of those many years ago, but I think I recently sold the tube and screen assembly. Can you give me the approx. size of the transformer as I may still have that. Failing that I can rewind it.
You could also rewind it by carefully dismantling it and counting the turns/measuring the wire.
Ed
Ed_Dinning is online now
Old 17th Dec 2018, 9:23 pm   #5
Radio1950
Hi Bijen,
How did you determine that the transformer is unserviceable please?
As Wrangler says, they are durable.
Maybe get it checked further?
Could save time and money.
Radio1950 is offline
Old 17th Dec 2018, 11:33 pm   #6
Jaguar1964
Hi Ed & Radio 1950
The size od the transformer is aprox: 85mm x 65mm around the iron core & 85mm width ways across the winding`s
There are two transformers in the unit & Its the transformer that feeds the CRT that I need
Just to reply to Radio 1950 comments the unit did initially power up but but after a short while smoke appeared which seemed to come from the transformer and it quickly blew its fuses
with the transformer out of circuit the unit lights up but as soon as the transformer is connected the fuses blow
I guess there may also another underlining fault but in any event I think I will need a transformer swap / repair
Thanks again guys for your input
Regards
Bijen
Old 18th Dec 2018, 9:29 pm   #7
Ed_Dinning
Hi Bijen, you could try running the CRT transformer with no connections to its output (secondary) side. If it then does not blow fuses, it could be an external fault.
Ed
Old 18th Dec 2018, 10:29 pm   #8
Bazz4CQJ
Bazz4CQJ's Avatar
These are very interesting old machines. However, just like radios of the period, if they haven't been in regular usage, or have been stored in damp conditions, some care needs to be taken when trying to bring them back to use.
You describe yourself as a novice Bijen, I wonder whether you may have just plugged this into the mains when you first tried it, or did you have a Variac unit so that you could slowly raise the voltage from 0 to 240V? The latter is much the best way to do it, if you plugged it straight in to the mains, that in itself may have caused damage. Hopefully, you now have it stored somewhere where it is as dry as possible. Any residual damp will risk problems with the EHT.
I know someone who worked for Crypton; I'll try find his contact details and see if he kept any manuals.
B
Bazz4CQJ is online now
Old 19th Dec 2018, 12:19 am   #9
Jaguar1964
Hi Baz.
You're right I'm afraid I plugged it straight in (I shall know better next time) and I do believe before I bought it that it was stored in a dampish garage, although it's in a warm, dry, conservatory now.
If your contact can advise on the Transformer voltages that would be great help and I can try to source another one or get this one re-wound
It's just such a lovely and quite rare thing it deserves to be saved and restored, also it's a bit of English technological history.
Thanks for the help.
Best regards, Bijen
Old 19th Dec 2018, 10:25 am   #10
Dave Moll
Dave Moll's Avatar
Before rushing to replace the transformer, it may be well to follow Ed's advice above of disconnecting the outputs from the transformer to ensure that the problem isn't further "downstream". If you overload the output of a transformer, then the transformer will overload its power source.
Dave Moll is online now
Old 19th Dec 2018, 5:57 pm   #11
Andrew B
Andrew B's Avatar
I would contact Ed Dinning on here, his guidance is very helpful and he may be able to rewind yours.
worried about the electrons entering the circuit and the smoke leaving
Andrew
Andrew B is offline
