16th Dec 2018, 7:00 pm | #1 |
Ebc 81
Hi again, Are the ebc 81 and the 6ld 13 identical valves? Regards Dick.
16th Dec 2018, 7:12 pm | #2 |
Re: Ebc 81
r-type.org reckons they're "sensibly equivalent" so likely it'll work as a sub.
16th Dec 2018, 7:13 pm | #3 |
Re: Ebc 81
They appear to be. EBC81 is Mullard, 6LD12 could be Mazda. Either will replace the other.
16th Dec 2018, 7:14 pm | #4 |
Re: Ebc 81
Sensibly equivalent according to http://www.r-type.org/exhib/aag0023.htm
19th Dec 2018, 5:29 am | #5 |
Re: Ebc 81
19th Dec 2018, 11:39 am | #6 |
Re: Ebc 81
Yes....sorry....just a typo The 6LD12 is much more familiar to me.....
My comment remains valid though.
19th Dec 2018, 7:32 pm | #7 |
Re: Ebc 81
Can the EBC 80 be used as well instead of an EBC 81. Regards Dick.
19th Dec 2018, 9:21 pm | #8 |
Re: Ebc 81
The valve museum classes them as suitable. The EBC81 is only 55mm high the EBC80 is 59mm so need to check the headroom.
Abosolute max ratings and pin out are the same, I have not checked the other specs. http://www.r-type.org/exhib/aaq0221.htm http://www.r-type.org/exhib/aag0023.htm
Frank |
