Old 15th Dec 2018, 2:47 pm   #1
Davewantsone
Default Roberts R66 - Local Oscillator Transformer
I recently bought a marooon coloured R66. After replacing a few capacitors and the rectifier diodes I powered it up first via a variac. It was completely dead on MW but worked brillantly on RTE LW and nothing else!
Further investigation I discoved the L.O.coil L7 was open circuit.
I decided to remove the can and dismantle it. The L7 winding is under the L5 winding. So I decided "how about putting a new winding on top of L5 in place of L7"? I measured L8 resistance (about 6 ohms) and thought the new winding would probably have less turns . So I picked around 4 ohms. I found some insulated copper wire of around the same diameter and after lifting the 2 capacitors in the can wound the coil on top of L7 and soldered the connections to the place that L7 would go. I resoldered the capacitors and put everything back in the can. I then resoldered the connections back into the radio.
I then switched the radio and was rewarded straight away with R4 on LW. I switched over to MW and that was now working properly with loads of stations and all I needed to do was a slight tweek of the trimmer capacitor to align the HF end of MW.
I now have a very nice looking and sounding R66
Davewantsone is offline
Old 15th Dec 2018, 5:21 pm   #2
ukcol
ukcol's Avatar
Default Re: Roberts R66 - Local Oscillator Transformer
Don't you love it when a plan comes together.
ukcol is offline
Old 20th Dec 2018, 11:08 pm   #3
JayBee66
No Longer a Member
I too bought a maroon R66 with the same fault. Picked up RTE and a few French stations but nothing on MW.
The same open circuit on the coil. A common fault or just coincidence?
https://www.vintage-radio.net/forum/...d.php?t=131898
Thanks for the solution. I suppose I'll get round to it, someday.
JayBee66 is offline
