Old 13th Dec 2018, 11:16 pm   #1
MikeEngland
Default AVO Multiminor MK5 photos required of RV1 connections.
Hello
I have recently come across a partially refurbished Multiminor Mk5, with some resistors having been replaced and the chap seems to have made a very nice job of it. Unfortunately the refurbishment wasn't quite finished and the leads to the potentiometer RV1 left disconnected. Could any of you good people post a photo of two of the three leads from RV1 and to where they are attached.
Many Thanks /Mike
MikeEngland is offline
Old 14th Dec 2018, 1:21 am   #2
Refugee
Refugee's Avatar
Default Re: AVO Multiminor MK5 photos required of RV1 connections.
Welcome to the forum.
It is not clear to me what part of the RV1 wiring you would like to see.
I have got one with a movement strip down needed. An internal photo of the movement would be useful while yours is stripped down if you are that far in.
ID:	174549   Click image for larger version
ID:	174550   Click image for larger version
ID:	174551   Click image for larger version
Refugee is online now
Old 14th Dec 2018, 1:51 pm   #3
ajgriff
ajgriff's Avatar
A copy of the manual including the schematic can be found by clicking on this link:
http://www.richardsradios.co.uk/AVO/...inor%20Mk5.pdf
This should help in making sure that RV1 is connected correctly.
Alan
ajgriff is offline
