11th Dec 2018, 10:17 pm | #1 |
Micronata low distortion generator.
Hi all.
Anyone know what powers one of these old testers? I've got two black wires hanging from the board. I suspect it's a PP9 or similar. Any advice? Thanks. |
11th Dec 2018, 10:48 pm | #2 |
Re: Micronata low distortion generator.
A bit more info or picture would help identify the model. A quick Google reveals several different items with similar names.
Chris |
15th Dec 2018, 8:59 pm | #3 |
Maybe this one
Micronta 22-9510 - LF Generator Peter |
16th Dec 2018, 12:11 am | #4 |
I have one just like Peter’s.
It takes 2 x 4.5V batteries in series to provide 9V. Type 1289 lantern, the flat one with the 2 brass strips on top. Originally came with a plastic piece that held the batteries together and provided the series connection. The 1289 is still available, I still see them at boot sales, usually Panasonic. Peter |
18th Dec 2018, 12:50 am | #5 |
Thanks Peter
18th Dec 2018, 7:22 am | #6 |
With unknown power wires + ground/ - can often be ID'd by looking at the PCB if any. Ground or - neg is usually easy because the ground plane on a PCB is thicker and the most common/plentiful trace , the - neg of electrolytic caps go to it, same to a point with +, ID'd by the pos of electrolytic/tant caps and the cathode of zener's.
Where it gets tricky is when you have two batteries in series with a ground/0v and pos/neg rails. Andy.
18th Dec 2018, 4:36 pm | #7 |
Just to clarify by "ground/ -" and "Ground or - neg" I mean ground as in a split rail supply or the negative of the battery terminal in a single rail supply, which ever is applicable. of coarse big fat traces could be neither if PNP trannies are used.
Andy.
Curiosity hasn't killed this cat...so far. Last edited by Diabolical Artificer; 18th Dec 2018 at 4:48 pm. |
