Old 10th Dec 2018, 7:49 pm   #1
linescan87
linescan87's Avatar
Default Pocket transistor id please.
Picked this up today from a second hand store while on my break. Anyone recognise it?
John Joe.
ID:	174309   Click image for larger version
linescan87 is offline
Old 10th Dec 2018, 7:55 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: Pocket transistor id please.
The tin-cased 'lozenge' shaped transistors suggest they're Newmarket - which will have "NKT" part-numbers.
This in turn hints at an early-sixties UK manufacturer (I don't recall NKT transistors being exported to Hong Kong etc. for fitment into "empire made" radios]
G6Tanuki is offline
Old 10th Dec 2018, 7:58 pm   #3
Andrew2
Andrew2's Avatar
I can't help, but it sure is a pretty thing. The styling is plain but attractive, something I always like. The only thing I recognise is the Newmarket transistors.
Andy G1HBE.
Andrew2 is offline
Old 10th Dec 2018, 8:53 pm   #4
ms660
ms660's Avatar
Pye P202BQ without the logo:
https://www.radiomuseum.org/r/pye_p202bq.html
Lawrence.
ms660 is offline
Old 10th Dec 2018, 9:13 pm   #5
linescan87
linescan87's Avatar
Hi lads, thanks for chipping in. I did think it was of British manufacture because of the license plate inside the back cover.
There seems to be an odd bit of grill stuck in a small square recess on the front, perhaps originally the was a makers plate or mark here
Yes Andrew, I do like it's styling. Very simple and it's in great cosmetic nick too. It seems to take 3 N size batteries.
Regards, John Joe.
ID:	174320   Click image for larger version
Old 10th Dec 2018, 9:18 pm   #6
ms660
ms660's Avatar
Regards, John Joe.
That's for the Pye logo referred to earlier.
Lawrence.
ms660 is offline
Old 10th Dec 2018, 10:45 pm   #7
linescan87
linescan87's Avatar
Hi Lawrence, phone froze while I was replying earlier. Thanks for the id.
John Joe.
Old 11th Dec 2018, 6:05 am   #8
TonyDuell
Correct. The Trader Sheet for this set says that it uses 3 Ever Ready D23 cells, which was their number for the N cell.
TonyDuell is offline
Old 11th Dec 2018, 8:11 am   #9
Neil Purling
Three N cells? Excuse me, but could you buy these nowadays?
Neil Purling is offline
Old 11th Dec 2018, 8:53 am   #10
Refugee
Refugee's Avatar
N cells?
NiMh would be easiest to get these days.
Refugee is offline
Old 11th Dec 2018, 9:29 am   #11
dave_n_t
dave_n_t's Avatar
Yes; my local Poundland sells (for £1!!) a 'mixed packet' of an N, an E23 and an E27, and one other. £1 for an 'N' might be expensive, but at least you get the others to play with....
dave
Dave Teague
dave_n_t is offline
Old 11th Dec 2018, 9:33 am   #12
Boater Sam
N cell, Lady battery, LR1. Used commonly in fish bite alarms. Door remotes, etc.
Still widely available, even on Amazon. Other suppliers are available, see ebay for reliable GP ones.
Boater Sam is offline
Old 11th Dec 2018, 9:35 am   #13
radioman
radioman's Avatar
'N' size alkaline cells are available from CPC :-https://cpc.farnell.com/w/c/electric...ry-size-code=n
and probably other places too.
radioman is offline
Old 11th Dec 2018, 11:35 am   #14
FERNSEH
FERNSEH's Avatar
Note the early employment of the miniature Toko type IF transformers.
DFWB.
FERNSEH is offline
Old 11th Dec 2018, 3:21 pm   #15
Andrew2
Andrew2's Avatar
A bit off-topic, but there's a good little story about IF transformers in (I think) the 3rd edition of Radio Radio.
It comes from one of the designers of the PAM 710 transistor radio. He said that because of the rather poor performance of early transistors, it was important to get maximum power transfer between the stages in the RF and IF strips. He was in charge of the in-house design of the IF transformers and went to great lengths to optimise the magnetic circuits and carefully manage the Q etc, even specifying brass pins to reduce any disruption of the magnetic properties.
However, when the production guys got hold of it they used standard steel pins which protruded into the magnetic parts, completely ruining the gain/bw performance. Rather than go back to the original design, they reduced the IF to 120 kc/s to get the performance back.
It must have suffered from some pretty bad images!
Andy G1HBE.
Andrew2 is offline
Old 11th Dec 2018, 5:05 pm   #16
peterpixel
Newmarket was a Pye company later taken over by GE.Their earlier transistors were designated V/10,V/30 etc later changing to NKT.It would be interesting to know which types are fitted as this might give a close date of manufacture.I have an booklet of application notes dated October 1959 and all the transistors in it are the V/ series.Peter.
peterpixel is offline
Old 11th Dec 2018, 5:21 pm   #17
Reelman
Reelman's Avatar
Morrisons definitely sells a Duracell packet of 2 N cells for around £3.50 I think.
Peter
Reelman is offline
Old 13th Dec 2018, 8:02 pm   #18
linescan87
linescan87's Avatar
Yesterday I obtained 3 N cells from Dealz (Poundland in Ireland) so last night I decided to have a go at getting this working. I replaced the electrolytics, as they were all showing signs of leakage.
I then cleaned the volume pot and wave change switch with servisol. It brings in Radio 4 on the light preset quite well and medium wave is quite sensitive.
Sadly the little lugs on the back are worn so the back cover fitting isn't as tight as it could be, but for 55 years plus it's in remarkable condition. I expect the N cells, being alkalines, will last a long time.
Cheers, John Joe.
