Old 19th Nov 2018, 10:14 am   #1
Phil G4SPZ
Phil G4SPZ's Avatar
Default Morrison’s Patent “Facile” Electric shade remover
Not electric itself (so Mods please delete if considered inappropriate) but a friend of mine owns this intriguing tool designed to remove the shade ring of early electric lampholders. Possibly dating from the 1920s, it consists of a cylindrical wooden handle topped by a rubber-lined cup, which grips the shade ring with sufficient friction to permit it to be unscrewed. Bakelite shade rings certainly became brittle and stiff to remove when exposed to heat. When electric lamp shades were narrow, this must have been a boon to every modern household.
An internet search has, unsurprisingly, revealed nothing. Few can have been sold, and even fewer probably survive.
Has anyone else seen anything like it?
Phil
Phil
Phil G4SPZ is offline
Old 19th Nov 2018, 8:22 pm   #2
Lucien Nunes
Default Re: Morrison’s Patent “Facile” Electric shade remover
There are current versions on sale today - search for 'shade ring wrench''. Somewhere I have the Westinghouse one that fits their US-style rings.
Lucien Nunes is offline
Old 20th Nov 2018, 8:21 am   #3
Phil G4SPZ
Phil G4SPZ's Avatar
Thanks, Lucien! You learn something new every day...
Phil
Old 20th Nov 2018, 10:11 am   #4
russell_w_b
russell_w_b's Avatar
I daresay this is common knowledge, but if you apply a little talcum powder to the Bakelite threads when the shade carrier is new, and also at subsequent removals, you won't need a fancy wrench.
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 20th Nov 2018, 12:20 pm   #5
Herald1360
Herald1360's Avatar
There's also no need for their being done up tight anyway.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 20th Nov 2018, 12:27 pm   #6
Boater Sam
Is this patent the same Morrisons as the present grocers I wonder? There are certainly none on sale in my local branch.
I remember the story of the lady used to gas mantles trying to light a new light bulb, with a match to burn the sugar off, new fangled things.
Boater Sam is offline
Old 20th Nov 2018, 6:46 pm   #7
Graham G3ZVT
Graham G3ZVT's Avatar
"Caution, one lamp looks the same as another"
was no doubt perfectly true, (I suppose it eluded widely differing voltage ratings available), but the warning was not exactly helpful to the householder in knowing what to do about it.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 20th Nov 2018, 8:17 pm   #8
Herald1360
Herald1360's Avatar
More likely to be implying that their lamps were better than the competition's.
....__________
Old 21st Nov 2018, 12:35 am   #9
Phil G4SPZ
Phil G4SPZ's Avatar
Well, it wasn't common knowledge to me, Russell, so thanks for the tip! Talc is also quite good for lubricating curtain tracks, but I digress.
I think the main point of the wrench is that some shades were too narrow for the hand to get right up and grip the shade ring.
I doubt that the patentee was the same Morrison who now operates supermarkets, but you never know!
I'm sorry that I cropped the photo a bit tight and cut off the bottom of the box, which I'm sure bore words along the lines of "So insist on Bloggs's light bulbs! Refuse imitations!"
Phil
Old 21st Nov 2018, 10:55 am   #10
Brigham
I have one of these...
...somewhere!
Brigham is offline
Old 21st Nov 2018, 9:18 pm   #11
russell_w_b
Here's the 1929 'SUNCO' version. A snip at 4/-.
Regds,
Russell W. B.
G4YLI.
Old 22nd Nov 2018, 12:12 am   #12
emeritus
And here's GEC's versions from 1912.
Thanks for the tip about talc.
emeritus is offline
Old 22nd Nov 2018, 1:41 am   #13
Phil G4SPZ
Phil G4SPZ's Avatar
Fantastic!
Phil
Old 22nd Nov 2018, 2:39 pm   #14
G6Tanuki
G6Tanuki's Avatar
Love it!
I vaguely remember seeing a similar sort of tool used in a lighting shop for fitting/removing the knurled brass rings used on some lampholders - it was a thin metal tube which had been multiply 'crimped' lengthways so it looked like it was splined. The inside of the splines were themselves knurled. The splined-ness of the tube gave it some elasticity so it could fit over the different sizes of knurled rings.
G6Tanuki is offline
Old 22nd Nov 2018, 3:16 pm   #15
Refugee
Refugee's Avatar
I can remember making a couple of new rings from a nut taken from a compression fitting.
I can't remember the pipe size now but the old ones were brittle plastic and had turned to dust. The light fitting is still fine though.
Refugee is offline
Old 22nd Nov 2018, 3:54 pm   #16
AC/HL
AC/HL's Avatar
What goes around... A new LED fitting my Daughter has in her house has three shades, too narrow to get your hand in, well mine anyway. It came with a plastic tool to fit the shade locking rings.
AC/HL is offline
Old 22nd Nov 2018, 5:28 pm   #17
Refugee
Refugee's Avatar
I made a plastic tool to fit the slices of pipe nut for mine.
Now I know what the tools look like perhaps I might find one at the flea market.
Refugee is offline
Old 22nd Nov 2018, 6:12 pm   #18
ColinTheAmpMan1
ColinTheAmpMan1's Avatar
Some of those things look like they could double-up as tooth-extraction pliers. Ouch!
Colin.
ColinTheAmpMan1 is offline
Old 22nd Nov 2018, 6:22 pm   #19
Boater Sam
Morrisons grocers date from 1899 so maybe it is the same!
Amazing that there seem to be various makers of these tools.
Old 22nd Nov 2018, 11:06 pm   #20
Phil G4SPZ
Phil G4SPZ's Avatar
Well, the friend who owns the item in post#1 also owns a second, different, example. I’ll be seeing him on Sunday so I’ll try to remember to photograph that one too.
Phil
