Old 16th Nov 2018, 11:29 am   #1
camtechman
camtechman's Avatar
Default Replacement Philishave Rechargeable Battery
My Philishave shaver, Model HQ6849 rechargeable Ni Cad battery has kicked the bucket and a quick search online provides a NiMH 2000Ah type as a replacement.
Would this type be suitable and would there be problems with charging ?
Your advice would be welcome.
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline
Old 16th Nov 2018, 11:35 am   #2
Peter.N.
Default Re: Replacement Razor Rechargeable Battery
If this is the 'wet and dry' type I changed the batteries in mine for the 'NiMH type a number of years ago and its still going strong. Brilliant shavers.
Tagged batteries available on ebay.
Peter
Peter.N. is offline
Old 16th Nov 2018, 11:41 am   #3
G6Tanuki
G6Tanuki's Avatar
Do you know what the capacity of the original battery is? I suspect it will have been rather less than 2000mAH. 700 to 1300mAH were typical values for NiCd cells.
If the charging circuit uses a simple series-resistor then fitting a larger-capacity NiMH battery should be OK, it'll just take longer to charge fully. If the charging circuit includes any sort of sensing system (like a diode to detect the battery getting hot) and a charge-cutoff circuit then this will not necessarily be NiMH-compatible though you'll probably get away with it, just keep an eye on it for the first few charges and see if it gets hotter than the old one did.
G6Tanuki is offline
Old 16th Nov 2018, 11:52 am   #4
paulsherwin
paulsherwin's Avatar
Charging is likely to be suboptimal but it probably won't matter. It may be better not to leave it permanently on charge when not in use.
paulsherwin is offline
Old 16th Nov 2018, 12:04 pm   #5
camtechman
camtechman's Avatar
G6Tanuki,
I have the original battery (just removed it) and not any info on it, except Ni-CD, Recycle but there is this string of numbers: 1.800.822.8837 (probably a Philips part number?) and it's the original one fitted from purchase some years ago,
Old 16th Nov 2018, 12:09 pm   #6
camtechman
camtechman's Avatar
Peter N,
If this is the 'wet and dry' type?
No, it's a basic model and bought sometime in the 1990's.
Old 16th Nov 2018, 12:12 pm   #7
camtechman
camtechman's Avatar
Paulsherwin,
No, only left on charge for about an hour prior to trimming and tidying up my English Civil War beard prior to an event.
Old 16th Nov 2018, 12:14 pm   #8
G6Tanuki
G6Tanuki's Avatar
Originally Posted by camtechman View Post
G6Tanuki,
That number is a US battery-recycling information hotline - See https://www.call2recycle.org/epa-cer...cycling-label/
If there's a Philips model-number on the shaver itself it may be worth searching for an old online ad for it which may give some specification details that include battery capacity.
G6Tanuki is offline
Old 16th Nov 2018, 1:05 pm   #9
Herald1360
Herald1360's Avatar
If you're really worried about MiMH problems, you can still get full fat NiCd.......
https://uk.rs-online.com/web/p/aa-re...eries/3783326/
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 16th Nov 2018, 1:10 pm   #10
camtechman
camtechman's Avatar
Herald,
Well spotted & I also need to place an order for other items too.
P.S. Here's a pick of the razor:
Name:	Philishave HQ6849 #2.jpg
Old 16th Nov 2018, 4:38 pm   #11
camtechman
camtechman's Avatar
Being fed up with funeral adverts on TV, I decided to have a go at the shaver and in my box of "one day they'll be handy" batteries in the cupboard, I came across a Ni-MH AA battery that looked unused with a rating of 800 thingy-ma-bobs.
30 minutes later, having blown away my previous beard shave, fitted the battery, re-assembled I plugged it in and WHOOPIE it started to charge and I'm leaving it to charge for an hour.
I cheated after 15 mins and it worked well and again after another 15 mins...……...I'll report later...…
Old 16th Nov 2018, 7:08 pm   #12
Herald1360
Herald1360's Avatar
Nothing to lose- worst case is just a dead NiMH but that'll probably take a few years!
Shaver looks remarkably familiar, though......
Guess they didn't reinvent the wheel.
....__________
Old 19th Nov 2018, 12:20 am   #13
McMurdo
McMurdo's Avatar
the one in my philishave is the same thickness as an AA and the same length as an AAA. It's an NiMh, an AA size is too long to get inside, it's the same shaver as post 12.
I scrapped the shaver as the proper philips battery was too dear.
Kevin
McMurdo is offline
Old 19th Nov 2018, 1:15 pm   #14
Herald1360
Herald1360's Avatar
Bother..... the cell in mine isn't wonderful- only about 2-3 shaves per charge these days.
Edit: Took mine apart and found it's definitely an AA size NiMH in there. Phew!
....__________
Old 19th Nov 2018, 1:29 pm   #15
Herald1360
Herald1360's Avatar
Cold comfort here:
https://www.batteriesplus.co.uk/acat...H_Battery.html
....__________
Old 19th Nov 2018, 7:44 pm   #16
G6Tanuki
G6Tanuki's Avatar
Surely "stick it back on charge for a top-up after after every use" would be the expected duty-cycle??
G6Tanuki is offline
Old 19th Nov 2018, 10:36 pm   #17
Herald1360
Herald1360's Avatar
Default Re: Replacement Philishave Rechargeable Battery
Maybe for an electric toothbrush which sits on a charging stand but the shaver has to be plugged in using the same lead as a mains operated one would have. Since there's a relatively complex switchmode fast charger built in I don't think it was designed for other than "charge it when it's flat" service.
Certainly it would go quite happily for a couple of weeks- probably ten shaves or so when it was new. It's on its third set of cutter heads now, so it hasn't done too badly, but £3 for a battery is more attractive than £30 for a new shaver!
....__________
Old 19th Nov 2018, 11:53 pm   #18
Alistair D
Alistair D's Avatar
This is an excellent site for finding cell types from their dimensions. Scroll down to see the table.
https://www.powerstream.com/Size.htm
Al
Alistair D is offline
Old 22nd Nov 2018, 7:10 pm   #19
sentinel040
Location: Near Lichfield, Staffordshire, UK, most of the time and Crystal Palace, S London, some of the time..
Alistair, thank you for that page it’s a mine of useful information.
Ian
sentinel040 is offline
Old 22nd Nov 2018, 8:40 pm   #20
camtechman
camtechman's Avatar
Just an update, my razor is still working fine, since I fitted the 800mA NiMH Battery.
