Old 25th Oct 2018, 2:24 pm   #21
Trigon.
Trigon.'s Avatar
Default Re: Retired Texas TI99/4A engineer needs help please.
Originally Posted by Boater Sam View Post
I know nothing of the UA723C or the TL331 chips other than they are hard to source in dil package and that they seem so expensive that I may well be wasting my time trying to go any further with the repair,
The 723 is available from Farnell for less than a pound! - UA723C
As for the TL331C, it does seem surprisingly difficult to find (one on eBay for £5) , but is it actually deceased ? Have you checked to see if the output sawtooth is present ?
Trigon. is offline
Old 25th Oct 2018, 2:44 pm   #22
Boater Sam
I don't have a Farnell account, is the UA724CNG4 the same chip or the UA724CN?
I have no knowledge of how TL331 works, I thought it was a comparator.
You say it should be generating an oscillating output? Presumably this is in the 20kc/s range to run the switch mode regulator chip?
Prices for these are crazy, is there a good reason?
Boater Sam is offline
Old 25th Oct 2018, 3:53 pm   #23
SiriusHardware
You don't need an account to buy from Farnell these days, Sam, those days are long gone. However you may be hit with carriage charges considerably higher than the price of the IC itself. You probably have to order goods to a minimum value (£20) before carriage is not charged for.
As well as the uA723 there was also the LM723, so worth looking for those too.
SiriusHardware is online now
Old 25th Oct 2018, 6:56 pm   #24
Trigon.
Trigon.'s Avatar
G4 is just one of the 'eco' suffices - basically means lead-free.
I have no knowledge of how TL331 works, I thought it was a comparator. You say it should be generating an oscillating output? Presumably this is in the 20kc/s range to run the switch mode regulator chip?
It is. It alternately charges/discharges C16, comparing the voltage with the reference set by R11, R15-20 and the positive feedback via R13 which creates the hysteresis defining the amplitude. The waveform is asymmetrical because the output is open collector, so it discharges via R14 but charges via R14+R12.
It's probably been obsolete for a very, very long time.
Trigon. is offline
Old 25th Oct 2018, 7:40 pm   #25
Boater Sam
Looking at data sheet for TL331 I can't work out the pin out connections with the 99/4A diagram.
The one on the board is 8 pin dil, can't find a datasheet for this old device only smc.
Old 25th Oct 2018, 7:55 pm   #26
Trigon.
Trigon.'s Avatar
Here you go:-
https://www.alldatasheet.com/datashe...TI/TL331C.html
Trigon. is offline
Old 25th Oct 2018, 8:21 pm   #27
SiriusHardware
And a datasheet for the uA723:
http://www.ti.com/lit/ds/symlink/ua723.pdf
If you want to check the functionality of the uA723 you could always breadboard the basic linear regulator application circuit from page 5 of the datasheet. It just needs the IC and a handful of passive components. (Suggested component values are on page 4).
I'm not suggesting this could be used as a substitute for the original switching regulator design (It can only output 150mA maximum), just to use it as a way of functionally testing the IC before you go buying another one.
If the uA723 IC doesn't even work in that basic linear mode then you can probably say that it is dud.
Old 25th Oct 2018, 9:16 pm   #28
Boater Sam
Thanks guys for your valued assistance. Where would we be without the forum.
If I can get all the monkeys waiting for brass welding out of the workshop this weekend I'll have a go at testing the chips. Even the spiders have died off.
If all fails I will have to see which way the guy wants to go with this,
Sam.
Old 8th Nov 2018, 3:30 pm   #29
Boater Sam
Thanks to Ron (ronbryan) I now have 2 fresh 723 regulator chips. Very generously donated.
So I thought I would 'scope the oscillator chip first.
Cleared some space on a very cluttered bench for the scope and set everything up.
Bah! The Telequipment 'scope has gone up in smoke! The other one is buried under lots of radios that I have put away.
So I'm discouraged and getting pressed for time now, pretty sure that the oscillator chip, TL331 is not working either. Briefly fitting a 723 did nothing.
Got to pack up and mothball the workshop in preparation for going away for winter. Its going to have to wait till late March when I get back.
Thanks to all for the assistance. Watch this space next year!
Old 16th Nov 2018, 4:36 pm   #30
dominicbeesley
dominicbeesley's Avatar
Sorry for the delay in getting back to you. I had a dig through the cellar today and I couldn't locate the modulator or PSU for the TI which means I've either lost them along the way or they've ended up in long-term storage. I did locate the TI itself if you want it?
I also located a water leak which has been doing damage to a few things so not a completely wasted task...
dominicbeesley is offline
Old 16th Nov 2018, 5:17 pm   #31
Boater Sam
Hello Dominic.
Wonderful, My pal would definitely like it, please PM me with what you want and can you send it?
I have a Hermes account.
No progress yet with the board, Its like "There's a hole in my bucket", first I need to fix the 'scope. I've ordered a LM339 to sub for the TL331.
Sam.
