Old 25th Aug 2018, 12:44 pm   #1
G4YVM David
G4YVM David's Avatar
Default WS19 set audio pick up...
Can I connect a speaker / phones to the pins of a 19 set and listen to the audio without going through the control box? I ask because a friends 19 set is with me and I was trying to see whether I could listen to it. It has no control box and I am not sure of the pins for audio. I did find one with a rather unstable 12v Dc on it. Clearly that's not the one, but I was just intrigued...
D
G4YVM David is offline
Old 26th Aug 2018, 7:54 am   #2
M0SOE_Bruce
Default Re: WS19 set audio pick up...
The "A" set audio output is pin 4 of PL2A. You can connect a speaker between it and ground. The output impedance is 100R as it's designed to feed multiple headsets.
M0SOE_Bruce is offline
Old 26th Aug 2018, 12:31 pm   #3
Orakle42
I agree with M0sOe Bruce, pin 4 is shown on the circuit diagram connected to a tap on T2A secondary.
Orakle42
Orakle42 is offline
Old 26th Aug 2018, 3:35 pm   #4
Keith
Keith's Avatar
For maximum output, you need to match the output impedance to that of the speaker. The required voltage ratio is SQRT 100/8 which is approx. 3.5. I have successfully used a small mains transformer for this connecting the speaker to the 6.3V winding and the output of the set between the 250V and 230V terminals.
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is offline
Old 26th Aug 2018, 9:30 pm   #5
G4YVM David
Thanks guys
D
Old 27th Aug 2018, 1:35 pm   #6
G6Tanuki
G6Tanuki's Avatar
If you're looking at doing this, you could do a lot worse than get hold of a "100V line" audio transformer: these have a range of tappings on both the primary and the secondary so can be frobbed to provide a whole range of impedance-matches.
Whatever, don't expect the result to be very loud!
G6Tanuki is offline
Old 7th Dec 2018, 9:22 am   #7
G4XWDJim
G4XWDJim's Avatar
Originally Posted by G4YVM David View Post
Jim I can't make it but I need a transformer, something like a heater transformer, to use as an audio transformer in my 19 set. I want to drop the 100ohm to speaker values 4-8 I guess.
I could pay postage
David,
I probably have what you need but most of my transformers are in several large wooden boxes which I can't get into just yet but is a heater transformer really what you need.
A 240/6.3 heater transformer has a 40:1 ratio which is much the same as the average valve radio audio output transformer and would probably replace the 19 set transformer without the need for an additional one.
If you want to tack an extra transformer to the headphone output it needs to be a much lower ratio, about 2 or 3:1. A little transformer which I think would get near this and is readily available and cheap is the Eagle LT700. It's a small transformer intended as the push pull output transformer for little transistor receivers and is less than an inch cube in size. The primary which you'd connect to the 19 set headphone output is centre tapped and would give you a couple of ratios to choose from by using half or all of it.
The other thing you could do is use a redundant computer speaker with internal amplifier.
Best of luck.
Jim
G4XWDJim is offline
Old 7th Dec 2018, 9:58 am   #8
G4YVM David
Jim
Two good ideas. I have an amp here in fact, but we were trying to make it self contained...
Thanks again
D
