28th Oct 2022, 10:18 am | #1 |
AM Pantry Transmitter
Not long ago, I picked up a pantry transmitter. It uses the 6BX6, EF86, and an EZ81 valve. It has the option to switch between LW and MW. It doesn't work at the moment, I will try to draw a schematic of it but might need some help with making it work. I will upload some photos very soon.
28th Oct 2022, 10:23 am | #2 |
Re: AM Pantry Transmitter
These are the photos of the front, rear bottom and top.
28th Oct 2022, 10:44 am | #3 |
Look forward to the circuit!
With those valves, it'll turn out to be a modulated oscillator, probably with screen-grid modulation to the 6BX6 (=EF80). |
28th Oct 2022, 10:45 am | #4 |
As an aside, is it still possible to buy that grill material?
Cheers Aub
28th Oct 2022, 10:48 am | #5 |
28th Oct 2022, 10:59 am | #6 |
It's called "Expanded metal" and most of the DIY sheds have a little section with things like bits of grossly overpriced short lengths of angle iron and other sections, you'll find it there, usually in aluminium.
28th Oct 2022, 10:59 am | #7 |
Hi yes wicks /B and Q Mick |
28th Oct 2022, 11:08 am | #8 | |
https://modelshop.co.uk/Shop/Raw-Mat...-holes/ITM6493 (They sell other sizes too) |
28th Oct 2022, 1:04 pm | #9 |
It's sometimes referred to as 'expamet' and come in all sorts of mesh size, gauge of metal, and sheet size.
It's commonly 1.2mm steel: These examples are from Screwfix. (They have others): https://www.screwfix.com/p/rothley-p...B&gclsrc=aw.ds https://www.screwfix.com/p/rothley-p...-x-500mm/447jp
28th Oct 2022, 2:05 pm | #10 |
Thanks all. Sorry to hijack the thread. Hope the pantry transmitter lives again.
Aub
28th Oct 2022, 9:50 pm | #11 |
The case looks like it is built, at least partly, from "Lektrokit". This was a range of standard metal panels, grilles, etc that could be assembled into neat enclosures for electronics. Sadly no longer available.
