Old 21st Aug 2022, 8:58 pm   #21
megasounds
Default Re: SINAD Meter - Home Made for £15.
Hi knoxieman
just a question
in your zip file there is a VER 3 sch.jpg file
Since i want to build one can you send me a proper and clear VER 3 sch.jpg ?
This one is very hard to read and some components are unclear.
many thanks in advance
PD9MWO
megasounds is offline
Old 15th Sep 2022, 6:15 pm   #22
megasounds
Name:	WhatsApp Image 2022-09-15 at 19.07.47.jpeg
Finally built the Ramsey Electronics version. Works great!
PD9MWO
Old 16th Sep 2022, 8:36 pm   #23
Cruisin Marine
Nice one!
"Behind every crowd, there's a silver Moonshine"
Cruisin Marine is offline
Old 21st Sep 2022, 6:08 pm   #24
sentinel040
Location: Near Lichfield, Staffordshire, UK, most of the time and Crystal Palace, S London, some of the time..
If I may, I would like to ask a question about this.
Having tried to get my paws on an original one, I started to build one of these a bit back when I first saw the post. I purchased the meter from the link provided and removed the internal series resistor (it helps). I used the 8V regulator from the original circuit (circa +/-4V). However, when I powered it up it would only give circa 25% of the fullscale deflection. When the test audio signals were applied, the pro-rata decrease in readings appeared to be about right, which was some encouragement.
I subsequently went through everything, and it all seems in order, the notch filter is nice and sharp and the input stage controls the gain nicely. The output from the rectifier hits the supply rail (more or less) in the positive direction and not quite in the other. So I was a little mystified. I checked the fsd of the meter and it is 1mA. Going into mild desperation mode increasing the supply to circa 15V (to give circa +/- 7.5V), then reducing the 6.8k resistors gave a greater scale reading, but not in a linear fashion. Now this is not nice, but in desperation they went dowm to 680 ohms and this gave just over fsd. I suspect the output stage of the op-amp is limiting the current, the datasheet states it is short circuit protected, hence daring to go so low with the resistors. Bodgery I know but I only want to try to get a feel.
I was wondering if the meters actually are supposed to be 1mA, as the one I received had a different scale.
Ian.
sentinel040 is offline
Old 24th Sep 2022, 4:38 pm   #25
megasounds
Originally Posted by megasounds View Post
Attachment 264773
PD9MWO
Finished !
