22nd May 2019, 2:18 pm | #21 |
Re: Things you unearth when you least expect….
Probably an early hard of hearing system. Our Church had one, the earpieces were issued on request, and plugged into a few of the pews.
22nd May 2019, 2:21 pm | #22 |
Ah, interesting. They were all on pews near the front - and it is a big church so that could be an explanation. They disappear under the floor so I have no idea where the other ends are.
Paul |
22nd May 2019, 2:31 pm | #23 |
Somewhere hidden behind the pulpit, maybe? Near a mains socket?
Or even in the actual base of the pulpit, if it's hollow. Look for a secret removeable panel or door! I'm really intrigued now 🤔 There must have been a mic on the pulpit, connected to some sort of PA unit (which would need a power supply)
Best Regards, Peter. Last edited by Lancs Lad; 22nd May 2019 at 2:41 pm. |
22nd May 2019, 2:35 pm | #24 |
The wiring in question is pretty ancient - pre war I would think so maybe a simple intercom sort of circuit? There is no sign of the other ends of the wire anywhere now but the PA system is at least the second to be installed so I imagine that anything around the pulpit was cut away many years ago. I only found the pew ends of the leads when I was putting brackets on the bottom to make them more moveable.
The pulpit is solid alabaster
Paul |
22nd May 2019, 2:54 pm | #25 | |
Not unreasonable given that 2A, 5A, 10A and 15A two pin plugs all existed at various times. Just for good measure, the L-N pin spacings were different from the three pin varieties, too. No continental style interchageability here!
22nd May 2019, 2:58 pm | #26 |
It was on the choir vestry which is always freezing cold so was probably for a heater. Surprisingly for a church built in 1898 it seems that there were never any open fireplaces anywhere
Paul |
22nd May 2019, 3:07 pm | #27 |
Was it an actual wall socket, or a plug-in double adapter?
Hope it wasn't for a heater, as it sounds like there would have been no provision for an earth connection
Best Regards, Peter. Last edited by Lancs Lad; 22nd May 2019 at 3:16 pm. Reason: Amending my grammar! |
22nd May 2019, 5:23 pm | #28 |
I will find it and post a photo. It is a two pin socket. No earth, but it looks very old indeed.
Paul |
22nd May 2019, 5:40 pm | #29 |
Here it is. The top cover with the holes in is made of wood
Paul |
22nd May 2019, 6:53 pm | #30 |
I think they were telephone type single headphones on a long handle for the hard of hearing.John.
22nd May 2019, 7:37 pm | #31 |
The only thing that makes me wonder about that theory is that the cable was single core wire rather than multi core flex. I suppose there may have been some sort of socket fastened to the pew for the headphone.
There are all sorts of redundant sockets and piping for gas lights dotted about
Paul |
22nd May 2019, 8:15 pm | #32 |
I wonder if those apparently single core wires actually contain two, very thin, separate cores.
Headphones have this sort of flex, with one sheathed core, and one bare copper core, enclosed in what looks like a single wire.
Best Regards, Peter. |
22nd May 2019, 8:22 pm | #33 |
No, it is very old twisted pair, silk covered bell wire.
Paul |
