18th Apr 2019, 2:21 pm | #1 |
Garrard AT-6 stereo cartridge, or whole headshell replacement?
Compatible types, please? It will be used as a stereo, with the other channel linked.
I've completed the power supply and amplifier restoration and sorted the intermediate wheel, so just this piece remains in the jigsaw! Thank you
Al |
18th Apr 2019, 5:01 pm | #2 |
Re: BSR AT-6 stereo cartridge or whole headshell replacement?
A thread title correction might cause less confusion for some, plus putting the post in the correct section of the forum.
Lawrence. |
18th Apr 2019, 5:41 pm | #3 |
AT6 is a Garrard model not BSR. We also need to know what amp or equipment the cart is to be used with. If a suitcase player, you would likely need a ceramic like a BSR SC12, but as I said we need more info.
Regards, Ben. |
18th Apr 2019, 6:21 pm | #4 |
Re: Garrard AT-6 stereo cartridge, or whole headshell replacement?
This is Al's other thread: https://www.vintage-radio.net/forum/...d.php?t=155674.
Title corrected and thread moved. |
18th Apr 2019, 7:25 pm | #5 |
Right..... A Dansette HiFi amplifier is quite respectable but will need a ceramic cartridge unless an extra preamp is fitted to go for a budget magnetic type (that's about as good as the AT6 will manage to track).
The "Chinese Cheapy" gives a reasonable account of itself for next to nothing if you make up your own mount to match the standard half inch of the AT6 headshell. Rather more if you manage to find one with mounting clip supplied. A 9TAHC would have been good, but they're mostly dying of old age now. Don't know how the less wonderful 8T is faring. Otherwise, the usual suspects. All getting hard to find/expensive compared with a budget magnetic plus preamp setup.
19th Apr 2019, 5:32 pm | #6 |
Ah, thanks for fixing the confusion, Bill. Typo rather than cognitive error
The headshell has four internal connectors for soldering, which protrude into the available space ... hence have doubts over the physical compatibility (size) of a ceramic candidate like the otherwise excellent if expensive BSR SC11M. Anyone confirm if ok from the size viewpoint ? Thank you
Al |
19th Apr 2019, 6:16 pm | #7 |
There's plenty of room for the SC11M, and the vast majority of other cartridges. Just make sure the cartridge comes with the mounting bracket.
20th Apr 2019, 10:26 am | #8 |
The Chinese Cartridge cost me £2 and the Bracket cost £7! Funny old world.
Cheers John |
20th Apr 2019, 10:30 am | #9 |
I made my own bracket for a cheap Chinese cartridge using the ally strip from round the top of a wine bottle.
Graham
Half my stuff is junk - trouble is, I don't know which half! |
20th Apr 2019, 10:37 am | #10 |
I know it has been mentioned before, but if you need to play 78s then this clone of the sc12 ought to be useful, and at about a third of the going price of the real deal. Again, no fitting kit but one can be made up as llama says.
Regards, Ben. |
20th Apr 2019, 1:09 pm | #11 |
Ben, this is listed as MM with an output of just 4mV.
Edward. |
21st Apr 2019, 9:17 am | #12 |
Thank you all,
Al |
21st Apr 2019, 7:42 pm | #13 |
Edward That is a ceramic cart. The people selling them put that MM spec on them all.
They are idiots. |
14th May 2019, 1:30 pm | #14 | |
I have sourced a new old stock SC11M with mounting bracket. The original cartridge had an integral method of flipping the stylus over to play LP's or 78's. This can't be preserved as the mech was riveted to the cartridge. It doesn't show as a deficiency of any kind, it's more for authenticity. The SC11M I have sourced doesn't appear to have any output. I've cleaned up the verdigris from the push-fit copper connectors and tightened them up a bit, and I've also scraped the connectors on the SC11M. This should be one of the most trivial things I've ever done in a whole restoration if the cartridge is working. Any ideas? It's a simple matter of an electrical connection if the cartridge is doing what it should be. Obviously I've done the simple test of checking for continuity to the amp input using the finger/hum method.
Al Last edited by Al (astral highway); 14th May 2019 at 1:40 pm. |
14th May 2019, 1:52 pm | #15 |
the finger / hum test you did was this touching the cartridge wires with the headshell in the arm?
are you connecting the cartridge using just 2 wires? if so check you have connected the cartridge up correctly |
14th May 2019, 2:40 pm | #16 |
It's very rare indeed for an SC11m to be faulty, I have to say!
Post a pic of your connections, please, Al. And/or scope the output while you stroke the stylus. N. |
14th May 2019, 4:51 pm | #17 | |
That's reassuring - or is it! - thanks Nick! they're expensive little units, so I hope I don't have to start over I'll ' scope it, may take me a day or two.
Al |
16th May 2019, 11:53 am | #18 |
does the cartridge have ( made in England )
moulded on the back? |
21st May 2019, 6:33 pm | #19 |
Just checked...no, it doesn’t
Al |
21st May 2019, 6:36 pm | #20 |
then its not a genuine bsr cartridge
