Old 7th Sep 2011, 11:42 am   #61
Amraduk
Default Re: 4 Digit Up/Down Counter IC?
Hello Stephen,
Originally Posted by val33vo View Post
Just forgot to mention that you can get very keenly priced PIC micros at a company called Crownhill associates.
Thanks. I have seen their ads in various magazines but had forgotten about them!
Regards,
Dave.
Amraduk is offline
Old 7th Sep 2011, 12:09 pm   #62
neon indicator
They are very expensive.
neon indicator is offline
Old 7th Sep 2011, 12:57 pm   #63
Andy Doz
Andy Doz's Avatar
Look at the Gemini range here:
http://www.redlion.net/Products/Digi...unterRate.html
I used to maintain equipment (particle accelerators) with these in. Rate shouldn't be an issue.
Andy Doz is offline
Old 7th Sep 2011, 8:36 pm   #64
Amraduk
Hello Andy,
Thanks for the suggestion, though they are much too big, I'm afraid! I need a 4 digit display approx 30mm x 7mm.
Regards,
Dave.
Amraduk is offline
Old 7th Sep 2011, 8:46 pm   #65
neon indicator
They are also about £100
Old 7th Sep 2011, 11:48 pm   #66
Amraduk
Hello Michael,
I didn't go that far. That is far too much!
Regards,
Dave.
Amraduk is offline
Old 8th Sep 2011, 2:51 pm   #67
mhennessy
Hello Dave,
I had a bit of a play over lunch, and this is what I turned up...
It's a simple "proof of concept", using bits from our PIC teaching equipment. I'm using the PIC16F84 to drive the multiplexed 7-segment display and count pulses (produced from switches because we don't have any rotary encoders here at the moment).
The code is 133 words (891 free), and only 7 variables are in use. It's fair to say that this most lowly of PICs is somewhat over-specified
I've made no attempt to optimise things; what you see is rough and ready, but working. As we still don't know what the maximum count frequency will be, it's hard to test it further, but seeing as this is replacing a mechanical counter, I guess it's a bit arbitrary really.
As a learning exercise you'll probably want to write your own code, but this might help to get you started. On the other hand, now that I've gathered everything together in one place, I'm happy to work with you and finish this now. I haven't written the routines to save the count value to EEPROM - doing so might require a PIC with more I/O and an external power-fail circuit (assuming Microchip haven't built this in yet).
As it happens, I'm going to set this as an exercise for our more able students in future. We only get 4 days with them, so this is about as far as we can take things in that time, but occasionally we get people who have done this before and need stretching...
Comments welcome, but please bear in mind everything above, and only if they're constructive. Please remember, this was about 30 minutes work in a lunch-break
Sorry about the dim LEDs (they are ancient), and the .txt file ought to be .asm
Cheers,
Mark
EDIT: When the comments in the code say "NPN", they should say "PNP". I used 2N3906, but almost anything will do...
ID:	56005   Click image for larger version
mhennessy is offline
Old 8th Sep 2011, 4:05 pm   #68
jimmc101
jimmc101's Avatar
That's quick, I think you're right about I/O; another interrupt for 'power-fail' would really be useful.
How about changing to a 16F628A and using the internal oscillator option.
This would free RA 0 1, 2 , 3 ,4(!Open drain), 6 & 7 for the segment drives. (RA 5 is input only).
Using RB 0, 1, 2, 3 for the digit drives leaves RB 4 & 5 for the encoder and RB 6 for the power-fail line.
RA 5 or RB 7 could be used for a 'Zero' button.
Using 'interrupt on change' of RB 4 to 7 allows both both the encoder and power fail to be interrupt driven.
As an additional benefit all four edges of the encoder could be decoded allowing up to four times the count per revolution of the encoder.
Jim
jimmc101 is offline
Old 8th Sep 2011, 4:32 pm   #69
Amraduk
Hello Mark,
It's very interesting, thanks for taking the time to do that!
That isn't important at this stage, the rotary encoder can wait.
Which just goes to show that a more powerful PIC isn't required!
I have no idea how fast the spools rotate during fast winding, I'll have to see if I can devise a method for measuring it.
I'm sure it will, and yes, I would like to write my own code as I expect I'll learn more that way.
I can more-or-less follow the listing you provided, though there are parts that will need some explanation.
Thanks, I dare say I'll be asking questions!
Again, that's not so needed at this stage, proving the concept is the important thing. I wouldn't be surprised if they have included power-fail option in one of their later PICs.
No problem, they show the count well enough.
Noted about PNP! I'm sure I'll have a suitable transistor at hand for switching the 7-segment LEDs.
Regards,
Dave.
Amraduk is offline
Old 8th Sep 2011, 4:58 pm   #70
mhennessy
Hi Jim,
Yes, all good points. I only used 16F84 because that's what these old training kits were designed around (and to be honest, it's not worth changing to anything else for what we do in 4 days). I've got a couple of 16F827As here, which are very similar to the '628A, so could experiment further...
Good point about the reset button - I forgot to mention it above or in the code, but in the absence of a spare input, I thought I'd use /MCLR (which feels like "cheating" somehow ). This would be fine as the code stands now, but obviously wouldn't work for the EEPROM version (the 16F84A doesn't have a PCON register to allow you to differentiate from power-on reset and /MCLR reset).
I used the RB4-7 IRQ for the rotary encoder for my preamp, thinking along the same lines. In the end, I found that doing it the "simple" way (like this code does) was fine for that, but as the pulse speed could be higher here, that's a useful option to reserve.
The 4MHz internal oscillator should be fine if it can keep up with the incoming pulses. We really need more information about this (Dave, that's a gentle hint )
Mark
Old 8th Sep 2011, 5:01 pm   #71
davegsm82
davegsm82's Avatar
You could find your maximum count speed by attaching a frequency counter to the least significant bit of the rotary encoder (I presume its one of those 'grey code' counters, as opposed to binary) and then winding your spools forward and backward.
The LSB will change most often and will be an indicator of the highest count rate.
Dave.
davegsm82 is offline
Old 8th Sep 2011, 5:09 pm   #72
mhennessy
Hi Dave,
It'll be a quadrature encoder, so two square wave outputs 90 degrees out of phase. These encoders have a variable number of cycles per revolution; the one I used gives 128 per revolution. So to find the frequency, multiply that by spool speed.
I said "it'll be" because I don't think it's been selected and installed yet. Looking at the first post, the current device is mechanical - meaning Dave has some work to do - and my advice would be to choose the fewest cycles per revolution. In fact, I'd be tempted to DIY something, especially given the cost of quadrature encoders . A lot of old VCRs used these under the spool tables - they were reflective foil with black segments, and a pair of IR LEDs/phototransistors underneath - these could easily be modified for this application...
Cheers,
Mark
Old 8th Sep 2011, 5:16 pm   #73
davegsm82
davegsm82's Avatar
Hi Dave,
Yes, I *think* (although not sure) thats called the "Grey" code, truth table;
X AB
0 00
1 01
2 11
3 10
You'll notice it differs slightly from binary, it gets really confusing with more than 2 bits.
I remember seeing those silver and black foil encoders on the bottom of video deck's, quite clever little things, espeially when you consider that the opto's were on the PCB facing upwards and the distance between them was engineered in!
Dave.
Old 8th Sep 2011, 5:37 pm   #74
ppppenguin
ppppenguin's Avatar
Gray Code http://en.wikipedia.org/wiki/Gray_code
The idea is that only 1 bit changes at any step so you are never left wondering if another bit should have changed at that step. Widely used for shaft encoders for that reason.
ppppenguin is offline
Old 8th Sep 2011, 5:41 pm   #75
mhennessy
Hi Dave,
Yes, you're right, the output is, strictly speaking, a Grey code because only one bit changes with each state. But with 2 bit Grey codes, there is no MSB and LSB; they both have the same frequency. Physically, it's just the spacing of the opto-couplers around the circumference of the spinning disc that gives the 90 degree phase shift. (That's yet another variable that had to be designed into VCRs - never underestimate the skill involved with production engineering )
Grey codes are used for absolute position sensors, with many more bits - as you say, these get very confusing indeed
Attached is another example - I rescued this with a view to DIYing something (again, rotary encoders are very expensive to buy - the one I used in my preamp now costs £50 ). This one came from an old Thorn lighting desk - the operator would drive this by sliding a fingertip on the toothed belt (all rotting away now) on the top surface, which in turn spins the disc. The light source (4 LEDs) is clearly visible on the small PCB, and the photo-transistors are just visible under the disc. I reckon I could mount that disc on the end of a tuning drive spindle, and use it with some slotted opto-isolators or similar...
Cheers,
Mark
Old 8th Sep 2011, 6:16 pm   #76
Brian R Pateman
Brian R Pateman's Avatar
This seems like taking a very large sledgehammer to crack a very small nut.
Encoders are not necessary, a simple magnet on the turntable, a cheap hall effect sensor and one of these would do the job at the cost of about £25.
I've attached the datasheet for the counter.
Forgive me if I sound like a Luddite, I just find simple low cost solutions preferable to expensive complexity and rather more elegant.
Brian
Brian R Pateman is offline
Old 8th Sep 2011, 6:22 pm   #77
ppppenguin
ppppenguin's Avatar
I agree that looks like a nice simple solution and saves re-inventing the wheel. Perhaps I'm being thick, but how would this know which direction it is rotating and hence whether to increment or decrement the count.
Old 8th Sep 2011, 6:23 pm   #78
mhennessy
Hi Brian,
The only problem with this is detecting the direction of rotation for counting down. Perhaps a second hall sensor might work? EDIT: Hmm - probably not...
The OP has stated that he doesn't want to hook into the mechanism to detect when it's being driven in reverse. Also, R2R tape machines might be driven by hand when editing, which is another reason to use a quadrature encoder.
The code is already there (though has plenty of scope for enhancements) - indeed I could send him a programmed PIC. If the encoder could be DIYed, and he already has the miscellaneous bits (like the LED displays, etc) then it's a very cheap project so far
Mark
Old 8th Sep 2011, 7:10 pm   #79
jimmc101
jimmc101's Avatar
What about recycling the bits from an old mouse? e.g. http://members.shaw.ca/swstuff/mouse.html
For one or more pulses / turn it's easy enough to make your own replacement disk with only one or more slots or vanes.
(Yes I am a cheapskate )
Jim
p.s. If the site seems to ring a bell think ESR meters
jimmc101 is offline
Old 8th Sep 2011, 7:32 pm   #80
mhennessy
Hi Jim,
Love it! It's something I've often wondered about (as the collection of mice in the attic will attest), but it appears that this guy has a bigger collection of round tuits than me
There you are, Dave; no shortage of money-saving ideas
I reckon the reflectors from an old VCR might be the best bet as these probably wouldn't need dividing down - but dividing down can be done in software if required...
Mark
