21st Nov 2018, 9:40 pm | #1 |
Vintage transistor ?
Here's a tiny device that came out of an old radio. It looks like a transistor but has no markings on it. The circuit board it was soldered to is broken and was given to me to play with. Any idea as to its identity please ? The board also has two BF495 transistors and a number of coils.
21st Nov 2018, 9:42 pm | #2 |
Re: Vintage transistor ?
Certainly a transistor ,why do I think BF947??
21st Nov 2018, 9:52 pm | #3 |
It is certainly an HF transistor. Could be either germanium or silicium. I think the yellow colour coding can be found somewhere in some data sheet, but which? The best way to find out, is to look up a schematic for the set it came out of. I hope you wrote down the make and model. Or else the printing on the PCB's may give someone a hint.
21st Nov 2018, 9:52 pm | #4 |
And here's the PCB I desoldered it from.
21st Nov 2018, 10:01 pm | #5 |
The board looks like some sort of VHF preamp or tuner.
21st Nov 2018, 10:05 pm | #6 |
My best guess is that it may have come out of a Roberts radio, but I don't have any other bits from the radio. It looks a bit like a Mullard module to me, the ones that have the hairy AF117s on them.
21st Nov 2018, 10:14 pm | #7 |
Or BFR90 or all sorts of UHF transistors. Even some MMICs went in that sort of package. 1980s onwards. Not very vintage.
22nd Nov 2018, 12:52 am | #8 |
Those "pill" packages with yellow or green paint used to feature in things like ELC1043 tuners- perhaps there was a grading for RF or mix/osc duty as with previous transistor series. Once something with sufficient performance for the top of Band V was being churned out in swarms, they might have had a low enough unit price to percolate down to less demanding use like the above.
22nd Nov 2018, 1:24 am | #9 |
That case is a TO-107: quite a rare package. 2N1561 and 2N1562 spring to mind: PNP germanium; VHF amplifier; Vce (max.) = 25v.; 250 mW Ptot; manufacturer = Motorola.
Al. |
22nd Nov 2018, 7:22 pm | #10 |
Philips/Mullard for sure. Could you take a picture in which any numbers on the copper side are readable? Also, what are the date codes on the BF transistors? If it happens to be used in continental models there's a chance I can find something. Other people might have Mullard schematics in case it's a British design. I would date it on first sight mid to late 1970's, so chances are the transistor is a silicium NPN type or possibly a MOSFET. In older RF modules, especially for TV, germanium PNP types with this casing were used. You could use the diode setting on your meter to determine the polarity and the material.
22nd Nov 2018, 8:19 pm | #11 |
Maybe something like a BFR90, used as a front end.
https://www.digchip.com/datasheets/p...BFR90A-pdf.php Nick |
