Old 1st Mar 2014, 4:45 pm   #61
ben
ben's Avatar
Default Re: Cassette Recorders
Alcohol will likely dissolve these rollers, it is very risky. Some hot water with a drop of washing up liquid might be better.
Regards,
Ben.
ben is offline
Old 1st Mar 2014, 5:39 pm   #62
Andrew2
Andrew2's Avatar
At our workshop, we always cleaned pinch rollers with isopropyl alcohol.
it brought off all the oxide and other grub without any sign of damage.
Andy G1HBE.
Andrew2 is offline
Old 1st Mar 2014, 8:12 pm   #63
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
I, too use isopropyl alcohol to clean heads, pinchrollers, etc., and have never known it cause a problem. In the past I've also used Methylated Spirits for these jobs, though not for ages.
'LIVEWIRE?' is offline
Old 2nd Mar 2014, 1:26 am   #64
ben
ben's Avatar
I always use alcohol on rollers in anything made within the last 20 -odd years, but after a couple of bad experiences with 35 year-old-plus kit (philips and tandberg), I'd advise against using it on the really old gear. Each to their own of course, but don't say you weren't warned! ;-)
Regards,
Ben.
ben is offline
Old 2nd Mar 2014, 9:35 am   #65
sp10mk11
sp10mk11's Avatar
I found meths great for removing old belt goo but on old pinch rollers a no no, alchohol is as far as I go with old rollers
sp10mk11 is offline
Old 2nd Mar 2014, 7:25 pm   #66
Steelemaneric
Big Dave who supplied the belts for my EL3302 recommended a selection of cleaners for removing the goo. Cif, Jif, Tcut and Gunk engine cleaner I used Jif and Cotton Buds which got rid of the horrible stuff. The little recorder gives quite a nice crisp large sound for such a small device. However I got into trouble because her indoors doesn't appreciate Carl Perkins Blue Suede Shoes as much as I do and there isn't a jack socket which is surprising. I don't think it has ever been used. It was given to my Wife in the early 90s by a friend who was de-cluttering. I believe it might have been an unwanted Christmas
present.
Eric
Steelemaneric is offline
Old 3rd Mar 2014, 2:23 pm   #67
jamesperrett
Philips were all DIN connectors at that time and the external speaker socket works fine with a headphone adaptor cable. Isn't there a headphone output on the 270 degree DIN connector too?
jamesperrett is offline
Old 6th Mar 2014, 6:17 pm   #68
Steelemaneric
Socket 1 which is a three pin DIN is the signal input / output and socket 2 which has a five pin DIN is designed to take the microphone remote control, headphones, a three way box and 7.5 volt mains supply. There is also a loudspeaker socket.
I'm going to give it a second pulley clean because the Wow and Flutter has got quite unacceptable. The belt has got tacky again. I'm going to use mentholated spirit this time. I might have to buy another belt kit.
Eric
Old 14th Mar 2014, 1:36 am   #69
Maarten
Regarding the date codes on the Aiwa, I have done some research and stumbled upon http://www.johnwolff.id.au/calculators/Canon/Canon.htm which explains a common Japanese dating scheme of the time, counting years from 1926.
This suggests 46.7.18 and 46.8.6 being 1971 date codes instead of 1964 date codes.
Maarten is offline
Old 14th Mar 2014, 10:04 am   #70
camtechman
camtechman's Avatar
Maarten,
Wow, what a find!
Well done, that now answers one mystery, although why Sony would introduce a 1964 Philips version in 1971 still leaves that part un-answered and probably we'll never know.
Many thanks, not just from me but, I'm sure from others too who will also find this date coding information very useful.
Tony
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline
Old 14th Mar 2014, 10:29 am   #71
Maarten
I'm guessing it was a 'cost down' design as was often the case when equipment was bought in. They would have had nicer and more expensive models in their own product line-up by then.
Maarten is offline
Old 14th Mar 2014, 11:30 am   #72
camtechman
camtechman's Avatar
One previous suggestion was that, as the Aiwa TP736 was on the market since approx 1965-1968 perhaps Aiwa had some excess stock and maybe Sony took up the opportunity to buy them at a low price?
Old 14th Mar 2014, 10:07 pm   #73
Maarten
Given a production date of 1971 this would mean they had an overstock in parts, not in assemblies or completed sets. This makes it a bit less likely in my opinion but certainly not impossible.
Maarten is offline
Old 15th Mar 2014, 7:54 pm   #74
camtechman
camtechman's Avatar
Maarten.
Just acquired a Sanyo M-747 cassette recorder, date stamp on motor: 46-11-12 and following the 'Hirohito' code, that'll be 12th November 1971.
Old 15th Mar 2014, 10:07 pm   #75
Maarten
Nice. I wonder how wide spread this dating system was and when it was discontinued (who knows, it may still be in use at some obscure manufacturer).
Maarten is offline
Old 16th Mar 2014, 5:14 am   #76
julie_m
It was fairly common practice in Japan to start counting the years from the beginning of each new emperor's reign.
When Emperor Hirohito passed on, it caused some computer problems in Japan. Apparently, some programmers had thought it disrespectful to entertain the possibility of an emperor being mortal and so hard-coded in the date; thus requiring extensive and complex modification when the event they were trying so hard to pretend was not going to happen, happened.
julie_m is offline
Old 16th Mar 2014, 11:25 am   #77
ScopeMonkey
ScopeMonkey's Avatar
Originally Posted by ajs_derby
It was fairly common practice in Japan...
It was, and indeed still is. These days it's more often done by writing a letter (either Roman or Japanese) in front of the year number to signify which reign it's in, though one does still see years written as just a number, where it's expected that the reader will simply know which era is being referred to.
There are also tables published of list of what year it would be if each era had continued rather than ended, for use when something (e.g. an electricity meter) has stamped on it something like "Replace in Showa 73", but the Showa era ended in 1989 (or in the Japanese system, Showa 64).
For reference purposes if anyone's interested:
Meiji era = 1868-1912
Taisho era = 1912-1926
Showa era = 1926-1989
Heisei era = 1989-present
Ed.
ScopeMonkey is offline
Old 16th Mar 2014, 5:55 pm   #78
Mike Brett
Just a small problem that someone might have an easy answer for.I have a couple of pre-recorded cassettes that for some reason seem to be jamming in my cassette recorders. I have tried them in several machines and the results are the same, the tape either runs slow or stops altogether. Unfortunately these cassettes being pre-recorded have no screws in them but are glued together. Has anybody come across this and managed to cure the problem. As a last result I suppose I could try breaking open the cassettes and try fitting the tape and spools in another case, hopefully without damaging the tape.
Mike
Mike Brett is offline
Old 16th Mar 2014, 8:01 pm   #79
Nickthedentist
Nickthedentist's Avatar
I would do what you suggest, or spool the tape into an empty/donor cassette via the head/pinch apertures, using splicing tape to attach the old tape to the new leaders.
N.
Nickthedentist is offline
Old 16th Mar 2014, 10:09 pm   #80
ben
ben's Avatar
Quick fix: take the cassette between first finger and thumb, and gently squeeze the area around the spool apertures. This should flatten out the tape pack enough for it to run without jamming and allow you to copy the tape to fresh tape or to your PC.
Regards,
Ben.
ben is offline
