Old 15th Jun 2006, 12:25 pm   #1
boiss
boiss's Avatar
Default Battery acid corrosion
What is the best way to stop corrosion of an aluminium chassis caused by acid from dry cells? I have tried cleaning and soaking in a bicarb solution but after a couple of days the white deposit returns.
Cheers,
Boiss
boiss is offline
Old 15th Jun 2006, 1:13 pm   #2
Geoff G4ICD
Default Re: Battery acid corrosion
Try, Hammerite rust remover it is excellent! Goeff
Geoff G4ICD is offline
Old 15th Jun 2006, 4:51 pm   #3
wireful3
I have a recollection that Aluminium is attacked by caustic soda. It might well react with other alkalis as well.
This could explain the white deposit. Incidentally do the dry cells have an acid electrolyte? If it is alkaline, then vinegar may help. I seem to remember that boiling fruit in an aluminium saucepan makes it nice and shiny.
wireful3 is offline
Old 15th Jun 2006, 6:14 pm   #4
boiss
boiss's Avatar
The problem was started by acid from old dry cells ( Sal Ammoniac?) I cleaned the chassis with a wire brush and dremel etc and then left it in a bicarbonate of soda solution for a couple of days. Then washed it with warm soapy water. After about 2 days there were signs of white deposits again. I have now soaked it in WD40 but I am not convinced that this will cure it. the copper and brass bits are fine after the bicarb treatment. They were not put in the solution together and the solution used was not very strong.
I was wondering if anodising it might be a better long term cure.
Cheers,
Boiss.
boiss is offline
Old 15th Jun 2006, 6:19 pm   #5
ppppenguin
ppppenguin's Avatar
Freshly cleaned aluminium forms a thin oxide film within minutes (seconds?) of being exposed to air. Anodising is the process of thickening this film by an electrolytic process. Ali actually corrodes very readily. It's only the oxide film that stops it corroding away to nothing.
I suspect that the white deposit is a carbonate or chloride. I'm afraid my chemistry runs out about there.
ppppenguin is offline
Old 15th Jun 2006, 8:34 pm   #6
zak
Cheers,
Boiss
You have to neutralise it first.You should not use bicarb ,you will make it worse.!You can only use this on ACID. For dry cells use vinegar or lemon juice which is ACID (to kill the ALKALI)
zak is offline
Old 16th Jun 2006, 12:14 am   #7
Tim
Tim's Avatar
I have used vinegar on a cotton bud or toothbrush. I suspect Tomato Ketchup would work well too( very good for cleaning coins).
Take care to wash the vinegar off afterwards and tin the contacts.
Tim
Last edited by Darren-UK; 2nd Sep 2007 at 12:46 pm. Reason: Relevant typo corrected.
Tim is offline
Old 16th Jun 2006, 5:47 am   #8
John M0GLN
John M0GLN's Avatar
Are these copper and brass bits in physical contact with the aluminium? If so, that could be a cause, they form a galvanic cell, and aluminium being the most electro-negative of the two will corrode away.
Regards
John.
John M0GLN is online now
Old 16th Jun 2006, 1:57 pm   #9
Sideband
Sideband's Avatar
Tim
I keep a bottle of the clear vinegar in the workshop and find it ideal for cleaning all sorts of things and it should work well on battery corrosion but with aluminium, it must be washed off completely.
Rich.
Sideband is offline
Old 21st Jun 2006, 6:38 pm   #10
boiss
boiss's Avatar
OK, Thanks for the help, the vinegar appears to work a treat. That was a bad mistake putting it in bicarb solution. If it had been left another year or two it would have been unuseable (just powder.) I will lacquer the chassis part in an attempt to halt any further corrosion.
Thanks again,
Boiss
Last edited by Darren-UK; 2nd Sep 2007 at 12:47 pm. Reason: Reference to non-existent image removed.
boiss is offline
