30th Oct 2005, 11:37 pm | #1 |
Painting expanded metal speaker grilles
Has anyone found an effective way of re-spraying expanded metal speaker grilles? The grille on the set I'm restoring has had some of the gold/bronze coloured coating rubbed off. I expect this was originally anodised. Is there a way of re-painting the grille? The set can be seen in the attached image. Any advice on recommended methods and paints would be appreciated. Thanks,
Phil Harris.
Phil Optimist [n]: One who is not in possession of the full facts Last edited by Darren-UK; 1st Sep 2007 at 12:43 pm. Reason: Removed troublesome link and extracted and attached image therefrom. |
30th Oct 2005, 11:47 pm | #2 |
Re: Painting expanded metal speaker grilles
Hi Phil,
I use this stuff: http://www.homecrafts.co.uk/html/pro...t2=15&cat3=304 You can get it in Homebase. It's very easy to brush on (minimal skill required ) and the "antique gold" shade looks just right to my eye. I've used it on several DAC90As and a big Pye 18A (all about ths same period as yours) and it looked great: Very smart but not too "new". Nick. |
31st Oct 2005, 9:56 am | #3 |
Hi Phil,
I've attached a picture of my Bush PB53. The metal grille was originally painted so I stripped it and spayed it with a small can of "Plasti-kote Brass" and I was very happy with the result I would firstly apply some paint stripper to determine wheter it is painted or not. If stripper doesn't touch it must be anodise, in which case give it a good rub with 0000 of 00000 wire wool before spraying. Regards David Last edited by Darren-UK; 1st Sep 2007 at 12:41 pm. Reason: Removed ref to troublesome link in post #1. |
31st Oct 2005, 7:07 pm | #4 | |
31st Oct 2005, 10:44 pm | #5 |
Thanks to Radio Dave for the tips on spraying. Your set looks a beauty, but my grille is a little darker than yours - antique gold sounds about right - so I'll try Nick's tip and try brush painting first. As my set only cost me £3, it won't matter if I make a mess of it!
Phil
31st Oct 2005, 10:52 pm | #6 | |
All I did was remove the grille from the set and clean it in hot, soapy water with nail- or tooth brush. After thorough drying, just brush the paint on. Wear gloves unless you don't mind being seen at work with gold fingernails. It's dry within 5 minutes. As always, a couple of thin coats always looks better than one thick one. You're right, Dave's set has turned out beatuifully. I suppose it's down to what kind of effect you're after. Dave's Bush looks like it's just left the showroom, so a brighter shade of gold is spot-on. For my rather less pristine Pye, the "antique" finish looked just right too. Nick. Last edited by Darren-UK; 1st Sep 2007 at 12:22 pm. Reason: Excessive use of emoticons. |
14th Nov 2005, 9:30 am | #7 |
Hi All I prefer to spray speaker grills as the results are much better.I also prefer plasti-coat paint so far used it on a Bush TR130 and a Bush SRP31 record player and had good results but washing and rubbing is very important to get a good key for the paint and dents can be removed by gently tapping with a small light hammer.
Andy Last edited by Andrew c; 14th Nov 2005 at 9:33 am. |
14th Nov 2005, 12:01 pm | #8 |
Another advantage of spraying is that there is much less likelihood of clogging the openings in the mesh. Personally I would never brush paint anywhere that spraying could be carried out because of the (usually) superior brushmark-free finish, though I have to admit that the surface area of most expanded metal grilles is so small that marks probably wouldn't show in any case.
Tony |
14th Nov 2005, 7:48 pm | #9 | |
6th Feb 2006, 11:34 pm | #10 |
Just seen that the little glass jars of Plasti-Kote "Odds 'n' Ends" Antique Gold paint I mentioned above are also available in Wilkinsons.
Last edited by Darren-UK; 1st Sep 2007 at 12:23 pm. Reason: Retail price quote removed. |
5th Jun 2006, 9:15 pm | #11 |
Well, I've just got round to brush painting this expanded metal grille with the Plasti-Kote Antique Gold brushing paint recommended by Nick, and the results are fantastic When the set is reassembled I'll post a picture.
Phil
Phil Optimist [n]: One who is not in possession of the full facts Last edited by Darren-UK; 1st Sep 2007 at 12:26 pm. Reason: Quote removed (refers to deleted post). |
5th Jun 2006, 9:59 pm | #12 | |
Look forward to seeing it. Nick. |
6th Jun 2006, 8:32 pm | #13 |
On the subject of Plasti-Kote, has anyone used the chrome version ? if so, what does it dry like, a bit matt or nice and glossy like real chrome ?
7th Jun 2006, 6:51 pm | #14 | |
Jay
The light at the end of the tunnel is probably the headlight of an oncoming train |
8th Jun 2006, 12:23 pm | #15 |
Ed, I tried that without success. I found that the laquer I used dissolved the shiny finish as soon as it hit it. That was after I let the chrome dry for over a week. I have seen that plastikote have a laquer that is made especially for the metal finish. That should work but I didn't try it as it cost about £7 and didn't think it worth it.
Steve |
8th Jun 2006, 1:58 pm | #16 |
As i mentioned to darren i realy dont think this stuff is much good (as appose to the anteque gold which is excelient) to show how bad it is i have tacken a picture, i used an etch primer first followed by two coats of plastikote chrome and this was the result. i realy dont think a lacker woud do any good
Jay
8th Jun 2006, 5:24 pm | #17 |
I nearly bought some chrome paint from 'Wilko' today, but mindful of Jay's earlier comments I held on to my money. Incidentally, my local branch of Wilkinsons Home & Garden stocks a full range of Plastikote paints in both aerosols and jars, at cheapish prices.
8th Jun 2006, 10:46 pm | #18 |
Looking at the pic Jay has provided, the finished item looks like a lump of lead. Hardly what I'd call 'chrome effect' as claimed on the can. I don't suppose you could apply three of four coats and then polish it up?
Incidentally, I have also played with gold and silver enamel paints such as Humbrol. Certain lacquers and varnishes will also remove them if you're not careful. Last edited by Darren-UK; 1st Sep 2007 at 12:30 pm. Reason: Excessive use of emoticons (Yes, even I do it!) |
10th Jun 2006, 1:31 pm | #19 |
Here is a picture of the restored Alba showing the quality of the repainted grille using Plastikote brushing Antique Gold. The other pic shows the set in its original sorry state after I rescued it from the 2005 NVCF for £3!
Phil
Phil Optimist [n]: One who is not in possession of the full facts Last edited by Darren-UK; 1st Sep 2007 at 12:27 pm. Reason: Quote removed (refers to deleted post). |
10th Jun 2006, 2:12 pm | #20 |
Nice work, Phil, it looks v. smart now
Hope they had a good hol. Nick. |
