20th Sep 2018, 9:03 pm | #1 |
Arm resistance when playing halfway through records.
Hello.
I have a Philips Stella ST571A, it has a Garrard deck but the arm shows resistance when playing halfway across the record causing sticking. I tried tweaking the screws at the rear of the arm but it hasn't fixed the problem. Can someone advise what I can do to fix it? All advice will be appreciated. |
20th Sep 2018, 11:31 pm | #2 |
Re: Arm resistance when playing halfway through records.
I had the same problem with my "Conquest auto"
Try re-greasing the groove in the cam gear, It's what I was told to do for a BSR turntable and it worked for me. (if your deck isn't an auto-changer, then I can't help. Sorry) |
20th Sep 2018, 11:54 pm | #3 |
You don't specify which Garrard deck, but a common problem is the arm which nudges the trip pawls getting a bit sticky or the pawls themselves likewise. Remove the platter and look at the mechanism under while moving the tonearm manually and you should be able to see it.
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
21st Sep 2018, 3:20 pm | #5 |
thanks for all your help, problem solved
