Old 13th Sep 2018, 8:59 am   #41
Brigham
Default Re: Anglepoise bulbs
Those LED filament bulbs are also available in 'pearl' or 'frosted' form.
These are the types I use in 'non-vintage' applications, being indistinguishable from normal filament lamps.
Brigham is offline
Old 13th Sep 2018, 12:33 pm   #42
Skywave
Question Re: Anglepoise bulbs
Originally Posted by Herald1360 View Post
100W would be OTT for Anglepoise use.
Why? Excessive heat output? Probability of reduced bulb life due to the shade reducing dissipation of the heat from that bulb? Excessive light output?
Whatever, I've been using 100-W. incandescent bulbs in four Anglepoise lamps here for many years: no problems at all - just need to remember not to touch the shade!
Al.
Skywave is offline
Old 13th Sep 2018, 12:47 pm   #43
emeritus
I found that the original Bakelite lampholder of mine deteriorated due to the heat of a 100W bulb. I replaced it with a brass lampholder holder, which did require adjusting the springs to compensate for the extra weight. I now use 40W or 60W reflector lamps, of which I laid in a stock when they were still available.
emeritus is offline
Old 13th Sep 2018, 2:18 pm   #44
John10b
I’m currently using a 60w bulb, last one, so I will be getting a “modern” led, I will ensure the output is at least 800 Lumins preferable 1000 +.
John
John10b is offline
Old 13th Sep 2018, 5:00 pm   #45
Skywave
Arrow Re: Anglepoise bulbs
Re: post 43: fitment of a brass lamp-holder as a replacement. Your findings and solution are same as mine.
Al.
Skywave is offline
Old 13th Sep 2018, 7:29 pm   #46
John10b
I was considering using my brass holder with ceramic insert, but then I wondered about safety and the fact that there is no earth lead going to lamp. This lamp and all my stuff will pass to my grandchildren.
I tried and failed to run an earth lead up inside lamp so decided to fit plastic holder instead.
Mine is very old and I wonder do the slightly younger versions have an earth lead fitted?
John
John10b is offline
Old 13th Sep 2018, 8:24 pm   #47
AC/HL
AC/HL's Avatar
The earth is separated before the other two wires go into the hollow arm, and terminates on the spring anchorage.
AC/HL is offline
Old 13th Sep 2018, 9:24 pm   #48
John10b
Mine is fitted with a flat 2 core lead, I presume it’s original. Interestingly there is the “double square sign” inside the lamp holder, which today as I understand it means it’s double insulated, but can that be, this lamp is very old, when did the double insulated sign first appear?
John
John10b is offline
Old 13th Sep 2018, 11:06 pm   #49
Herald1360
Herald1360's Avatar
Al.
My reason for stating this is indeed the heat output from the 100W bulb. The early Anglepoise shades were bakelite (silver painted inside) and got quite hot enough with 60W even in good condition- a few years on with most of the silvering gone, they would stink even at 60W. A quick fix back in the day was to use a reflector bulb to protect the shade from the heat, 60W was bright enough, though I suppose you might have got away with 100W too.
Later lamps (clones?) with metal shades wouldn't have been fried by a 100W bulb, but would still have got very hot!
Nowadays, mechanical considerations apart, you could use as bright a low energy bulb as you liked.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 14th Sep 2018, 5:01 pm   #50
John10b
My Anglepoise lamp has a metal shade and the name on the side near the heavy base, I’m presuming it to be original.
I’ve just purchased an led bc bulb (100w equivalent) from Tesco for about £7, the output is 1000 lumins and I have just fitted it, the illumination is excellent, perfect for my bench work. The only observation is the length of bulb, 2 to 3 cm longer, but I have no problem with that.
John
John10b is offline
Old 14th Sep 2018, 5:20 pm   #51
AC/HL
AC/HL's Avatar
Dating guide: https://www.anglepoise.com/faq/view/...glepoiser-lamp
Or a bit more detail on the 1227: https://twelvetwentyseven.wordpress....ing-your-1227/
AC/HL is offline
Old 14th Sep 2018, 7:03 pm   #52
Skywave
My reason for stating this is indeed the heat output from the 100W bulb. The early Anglepoise shades were bakelite . . . etc . . .
Ah! I see: thank you. I have never seen - nor heard of - bakelite shades fitted to Anglepoise lamps. (You learn something interesting often on this site!) So perhaps my 'very old' all-metal Anglepoise isn't as old as I thought - not that that's relevant. IIRC & FWIW, it came my way about 1970.
Edit. Following the post above from AC/HL, (for which "thank you"), this Anglepoise of mine is of the 1960 -1969 vintage.
Al.
Last edited by Skywave; 14th Sep 2018 at 7:15 pm. Reason: Add the 'Edit'. And then further corrections!
Skywave is offline
Old 14th Sep 2018, 7:48 pm   #53
John10b
The post from AC:HL is very informative, thank you. As far as I can see no mention of the material the shade is made of, pity, as I didn’t know some were made of Bakelite either, but that is the good thing about this forum, I learn something every day.
John
John10b is offline
Old 14th Sep 2018, 11:00 pm   #54
Herald1360
Herald1360's Avatar
Well, it might not have been actual bakelite, but it was a hard black plastic of some sort and definitely smelled a bit when it got hot!
....__________
Old 14th Sep 2018, 11:28 pm   #55
Skywave
I have known certain types /makes of 'plastic' bayonet cap bulb holders to produce the most awful smell if they are substantially overheated . . . often caused by the (erroneous) fitment of an incandescent bulb of 100-W or above.
ISTR that that smell to be somewhat reminiscent of rotting fish Once smelt ... never forgotten!
Al.
Skywave is offline
Old 15th Sep 2018, 1:07 am   #56
AC/HL
AC/HL's Avatar
It would seem that Bakelite was used for a while due to post war aluminium shortages.
AC/HL is offline
Old 15th Sep 2018, 1:47 am   #57
Refugee
Refugee's Avatar
I can remember finding a broken plastic light shade that stank of fish when it was chucked onto a bonfire. It was a sort of cream colour.
Refugee is offline
Old 15th Sep 2018, 8:33 am   #58
John10b
I certainly remember the fish smell.
Many years ago the building manger of the very large workshop facility that I had just joined was convinced that a dead rodent had died in the air con, and was just about to call in the environmental team to look for it, however it turned out to be a double 13amp socket “cooking”, we all had a bit of a laugh over that.
John
John10b is offline
Old 15th Sep 2018, 11:10 am   #59
Richard_FM
Richard_FM's Avatar
I was thinking that metal shortages might have meant a switch to bakelite.
Hello IT: Have you Tried Turning It Off & On Again?
Richard_FM is offline
Old 15th Sep 2018, 2:41 pm   #60
emeritus
About 20 years ago a couple of our circa 20 year old lamp holders got the stinking fish syndrome, cured by fitting new skirts. A label on the lampholder of the MK pendant set I bought a few days ago says it is rated for lamps of up to 150W.
emeritus is offline
