23rd Aug 2018, 2:43 pm | #61 |
Re: Dansette Major Deluxe - too quiet
So what is the output level on the Chinese red and black cartridge? I've used a few and they seem to be usable on a xL84 valve amp without a preamp transistor.
23rd Aug 2018, 2:54 pm | #62 |
They give c.150/200mV output.
Edward. |
23rd Aug 2018, 3:12 pm | #63 |
Thank you Edward and all, I should have remembered that, I thought there may have been a different one recently made, thanks again.
Cheers John |
23rd Aug 2018, 3:15 pm | #64 | |
I "get away with" fitting the X5M, as it has enough output to drive a single valve amplifier, certainly for playing 45s and 78s, but LPs need full volume and could be argued as being on the quiet side. If it's a job for someone else, then the situation needs to be explained to them so that they understand the limitations. |
23rd Aug 2018, 3:39 pm | #65 | |
https://www.ebay.co.uk/itm/H-TC8-TC8...-/112771172043 As a prolific poster, it would help us all if you included links in your posts, but I don't remember you ever having done so.
23rd Aug 2018, 4:39 pm | #66 |
Not surprisingly, there has been a very high level of demand for these. Suggest members check that site regualarly. I do not act for, or have any association with, the supplier.
Edward. |
23rd Aug 2018, 7:35 pm | #67 |
www.Dansette.com stock these at £35. I bought one recently and all is well.
Regarding the output voltage, I have found this interesting and have had some previous posts on the subject. I asked how the output on some cartridges on Voice of Music, for example, can be quoted at a higher level than other sites, for the same cartridge. As I was told there is no universal standard for measuring the output voltages and therefore I have become cautious when looking for a suitable replacement. Cheers John |
23rd Aug 2018, 7:46 pm | #68 |
You will find that US cartridge suppliers usually quote double the mV output from that of the UK. It is quite usual to see cartridges that are rated at 800mV here in the UK, quoted at c.2V in the US. I've needed to import for the last 5 years now and am speaking from experience.
Edward. |
23rd Aug 2018, 8:10 pm | #69 |
Thank you Edward your comments have been noted.
Cheers John |
22nd Sep 2018, 4:02 pm | #70 |
Time for an update. I bought a nice little Chinese sig gen and hooked it up (the spec referred to a max output of around 1.2V but I could only see 0.5V on my meter) anyway it made enough noise for me to think - 'Yes - cartridge!' However, Les (Leslie555) has very kindly taken a look with a view to repairing the cartridge and reports that it appears to be working well....Aaaargh! Any further ideas?
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
22nd Sep 2018, 4:20 pm | #71 |
Can I just recap, when you do a buzz test with your finger do you get a good healthy buzz?
Also you might find the other thread on a Dansette of interest to you. Cheers John |
