8th Jan 2014, 5:02 pm | #1 |
HV line monitor oddity?
Not sure where to post this, so if it's misplaced, my apologies. This little gadget appeared a few weeks back on the post of the 20Kv line above our village. It seems to be a monitor of some sort, but it isn't connected to the overhead lines. It's solar powered and has an LCD display which is showing in turn: Rouge (red) 0001, Vert (green) 0000, then: 0000 before cycling round again (my translation). There are three 'buttons' which seem to need a magnet to operate them. The large round lens is, maybe, an indicator lamp which can be seen from a distance. There are a few of these hereabouts and I wonder how they work and are there similar things in other parts of the globe? Cheers, Pete.
8th Jan 2014, 6:59 pm | #2 |
Re: HV line monitor oddity?
Wild guess: optical rangefinder to monitor post movement? The lens could have a photodiode behind it. What does it say on it? There appears to be a manufacturers name near the bottom.
8th Jan 2014, 8:44 pm | #3 |
And that manufacturer's name appears to be 'Schneider' - as in Schneider Electric S.A.
Al. |
8th Jan 2014, 8:50 pm | #4 |
We have done so much, for so long, with so little, we are now qualified to do anything with nothing. |
9th Jan 2014, 12:22 am | #5 |
Fascinating stuff!
It monitors electric and magnetic fields to identify different fault conditions on the overhead lines. Looks like a Flite 332 or 335 depending on how far up the pole it sits.
9th Jan 2014, 9:25 pm | #6 |
Thanks for the info. It's an Easergy Flite 339 and is mounted about two and a bit metres above the ground. So, it detects the three fields from the three conductors with respect to earth? Does it report back to base in the event of a fault, or does it just flash the lamp? Cheers, Pete.
10th Jan 2014, 3:42 pm | #7 |
The web link says that it has a small radio transmitter.
