Old 15th Feb 2020, 6:46 pm   #1
Replicaright
Default WS No 19 mk111 Canadian
Hi
Although my 19 set works very well the meter when switched to AVC now takes about 5 minutes to show a reading. Any ideas on what to look for?
Jon
Replicaright is offline
Old 16th Feb 2020, 5:16 pm   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: WS No 19 mk111 Canadian
Anything from a noisy switch to a res gone high or a cap on AVC line and I presume all other meter functions are fine.
HamishBoxer is offline
Old 16th Feb 2020, 8:29 pm   #3
Replicaright
Hi
Checking the meter again today reveals that the other switched positions have no readings although the AVC eventually does.
Jon
Old 16th Feb 2020, 8:37 pm   #4
HamishBoxer
Could be sticky meter, try a tap on it and see if it is indeed sticking.
Old 17th Feb 2020, 6:10 pm   #5
Orakle42
Just an observation, if its like the MK11 both sides of the meter are switched. The negative side relies on one wafer for all but the Ae position. If nothing else appears wrong perhaps some switch cleaner in this area might help?
Orakle42
Orakle42 is offline
Old 18th Feb 2020, 8:32 pm   #6
Replicaright
Hi
Replacing an open circuit 1.2m r on the meter panel has restored the meter operations.
Jon
Old 19th Feb 2020, 7:29 pm   #7
HamishBoxer
Nice to be right!
