Old 31st Jan 2020, 9:59 am   #1
kernowcam
Default Frg7700 display issues
I have just decided to have a look at my frg7700 display problem.
One segment seems to be on I think all the time. Same one on each digit. ie the 6 looks like an 8 . I believe it may be a faulty chip , oki msm5524. So any ideas? And does anyone have a spare chip please? Quite rare.
kernowcam is offline
Old 31st Jan 2020, 10:02 am   #2
Jon_G4MDC
Jon_G4MDC's Avatar
Default Re: Frg7700 display issues
I have known leaky diodes to cause that sort of thing on a Kenwood.
If there are any used around it, it's well worth checking them before blaming a rare and hard to get driver IC. 2x 1N4148 fixed it for me!
Jon_G4MDC is offline
Old 31st Jan 2020, 12:36 pm   #3
kernowcam
Thanks jon I will lookout diagram
Old 31st Jan 2020, 1:30 pm   #4
orbanp1
Here is an interesting thread on that display chip:
https://www.hamradioforum.net/archiv...hp/t-2631.html
Also interesting is the Japanese web-page that thread is pointing to, where they started to reverse engineer the counter/display chip.
You need to run it through the translator though.
Regards, Peter
orbanp1 is offline
Old 31st Jan 2020, 4:23 pm   #5
Jon_G4MDC
Jon_G4MDC's Avatar
D24, D25 in the attached snippet were to blame for my TS130V doing strange things in the display.
Old 3rd Feb 2020, 2:26 pm   #6
PETERg0rsq
PETERg0rsq's Avatar
If it is just one segment on each digit, then it is very likely the chip that is faulty (MSM5524)
Unfortunatly this is virtualy unobtainable, and replacement with an alternative very difficult, as it does all the clock functions also!
However do check the board for dry joints/bad connections, and check resistor network RB01.
It could be the display, but unlikely, but worth measuring the volts from the driver chip.
If I recall correctly the display runs about -100Vdc and the driver chip sinks the volts to turn on the segment.
If it was one digit, then it would likely be a driver transistor
SPECIALIST.....Knows everything about nothing
EXPERT..........Knows nothing about everything
PETERg0rsq is offline
Old 3rd Feb 2020, 4:47 pm   #7
SiriusHardware
Kernow, how do you feel about ordering from China?
https://www.alibaba.com/product-deta...666429832.html
(If you search more carefully on Alibaba there is at least one seller selling them in ones, but it is not clear whether they are the DIP version or the flat-pack SMD version).
SiriusHardware is offline
Old 3rd Feb 2020, 7:32 pm   #8
SiriusHardware
I've noticed that there is a LED output version of this chip, the MSM5523RS. If it is generally pin compatible (I have not checked) you could either:-
Remove the VFD display and build / fit an equivalent LED display directly driven by the '23 IC,
or,
Fit the '23 IC, isolate the LED drive outputs from the existing display and introduce extra buffer / driver circuitry as required to allow the LED driver chip to drive the original display. This second scheme would have the merit of separating the actual display driving components from the complex, hard to get controller chip so if any of the drivers failed again you would just replace those. It would also keep the radio / display looking original.
