Old 16th Oct 2004, 10:02 am   #1
Station X
Station X's Avatar
Default Ageing of Carbon Resistors.
I have just started restoring a 1960s Valve Amateur Transmitter which is full of 1/2 watt 20% tolerance Carbon Resistors. On checking with a meter I find that most of them are high in value and very close to the 20% mark. I generally allow 25% before changing the resistor. A few of the resistors are over 33% high in value.
The tolerance of these resistors doesn't compare very well with those I have checked in much older radios.
My question is will these resistors continue to increase in value, or can I assume they have stabilised after 40 years? If the former, then while I have the radio in bits, I will replace the resistors which are in critical positions in the circuit.
Graham.
Graham. Forum Moderator
Station X is online now
Old 16th Oct 2004, 10:16 am   #2
Radio_Dave
Radio_Dave's Avatar
Default Re: Ageing of Carbon Resistors.
Hi Graham,
I've always assumed that they carry on deteriorating. What I find disturbing is how much some of the these resistors increase in value when heat is applied with a soldering iron . A resistor which is at the 20% tolurance boarder line can increase dramatically if it's in a position where it can get hot
Radio_Dave is offline
Old 16th Oct 2004, 10:21 am   #3
jim_beacon
jim_beacon's Avatar
Graham,
heat and ratinghas a lot to do with this, if the components are conservativlry rated and well cooled, they tend to remain stable, as for example, in an old Tek scope (you only change them when you've done something stupid.......), or an early valve radio, where there is a lot of space. In later equipment, where the closest rating was used to save space and cost, and the components are much more closely spaced, you tend to get more problems.
Jim.
jim_beacon is offline
Old 16th Oct 2004, 5:05 pm   #4
Norm_Leal
Hi Graham
In most circuits you won't find any improvement changing out of tolerance resistors. Some resistors open over time. These will need changing.
Even NOS resistors, made 30-40 years ago, may be high in value. Resistance increasing seems to slow down in time?
Norm
Norm_Leal is offline
Old 16th Oct 2004, 7:19 pm   #5
ukcol
ukcol's Avatar
Hi Graham
When I was a student back in the 1960s, I was told that one of the mechanisms by which carbon composition resistors go high in value was by molecule migration. Apparently in circuits where there are high voltages the molecules responsible for conduction migrate to the ends of the resistor leaving a high resistance part in the middle. This is a continuous process while the circuit is working until the component is more or less open circuit.
Regards
ukcol is offline
Old 17th Oct 2004, 8:06 am   #6
Sideband
Sideband's Avatar
Hi Graham.
Everything said so far is true. It also depends on the make of resistors used. The old 1/2 watt types were quite stable but most resistors tend to drift high after a time. There are others that will go low but these are generaly used in higher current parts of the circuit like HT feed or cathode bias and usualy if they are (or have been) overrun.
I think you have to make an educated guess as to which are the best resistors to change. From experience, I find that higher value type tend to drift higher, for example anode load resistors on AF amps (like 220k). They may drop perhaps 60v across them at low current and probably results in molecule migration at a higher rate than say a low value dropping only a few volts.
Rich.
Sideband is offline
Old 17th Oct 2004, 3:49 pm   #7
XTC
Hi Graham,
I'd check that the wattage of the resistors was right in the first place. If they've been run at or beyond their limits, they'd be expected to drift further than in a domestic set where they are generally conservatively rated.
Also, resistors have a voltage spec and this is often ignored. If a carbon resistor is subjected to more than its specified voltage , but within its wattage, it will show permanent changes in value in a very short time. Maybe the voltages they've been subjected to are higher than in a domestic set.
Sometimes I've found that old carbon composition resistors have values within spec when they are cold, but show really strange behaviour as they get warm.
Whether to replace and what with (NOS or modern) depends on the restoration objectives you have set yourself for this equipment. I'd be inclined to replace those resistors which were hard to get at later with modern 1 or 2 watt modern types, and leave those which were within, or just outside their tolerancees if they were easy to get at .
Generally, valve circuitry is pretty tolerant of resistor values.
Pete.
XTC is offline
Old 18th Oct 2004, 8:46 am   #8
Station X
Station X's Avatar
Thanks for all your replies. You all seem to agree that Carbon Resistors do increase their value with age and that this is due to overheating caused by over running and/or lack of ventilation.
Interestingly the three resistors which are furtherest out of spec are all screen grid droppers. I shall calculate whether they are being over run. I've yet to check the screen grid decoupling capacitors, but they are probably OK, as they are disc ceramics. There isn't a single paper capacitor in this radio.
This radio was built towards the end of the valve era and I wonder whether the resistors used were actually intended for use in low voltage transistor circuits. The radio uses 300 Volts HT.
I shall adopt a sensible approach as to which resistors to change for 2W 500V types in the interests of long term reliability. I won't change any for the sake of it.
Graham.
Old 18th Oct 2004, 1:11 pm   #9
Biggles
Hi all, it may be worth noting that a lot of older circuits appear not to be too critical of component values. I think that the designers were well aware of the limits of component manufacture at the time, and produced tolerant circuits. I think nowadays that we are used to picking a component up and testing it, and being surprised if it is more than about 1% out, because of modern production techniques. I have wasted a lot of time in the past " being the perfectionist " and replacing components that were just out of tolerance, only to find that it has made no difference at all to the performance of the set. Of course, if a component is proven to be shifting in value, or under-rated by design, then change it , but don't be too critical.
Biggles.
Biggles is offline
Old 18th Oct 2004, 3:08 pm   #10
Radio_Dave
Radio_Dave's Avatar
It might be worth me mentioning that I won a large quantity of the old nos Eire (I think thats how to spell them : ) resistors.
Although these have never been used alot of them are way out of tolurance. Maybe they were never too good from new!
Old 18th Oct 2004, 4:25 pm   #11
Norm_Leal
Hi David
This is true even with carbon composition resistors made 20 years ago. We had some 1 meg resistors that were on the shelf for a couple years. Many had incresed in value and were out of tolerance. This seems to be more of a problem with higher values which sometimes open.
They were good when received. Every incomming shipment was inspected and sample tested.
Norm
Old 18th Oct 2004, 4:50 pm   #12
XTC
Here's an interesting website talking about the wonders of carbon composition resistors.
http://www.tone-lizard.com/resistors.htm
I'd guess that the stability of NOS composition resistors depends quite a lot on the conditions they've been stored in, and that the ingress of moisture has a big part to play. 40 years in the average UK garage would be very different to 40 years in a garage in Arizona, say.
In the article, there's a picture of a bag of resistors with a silica dessicant. The author reckons that this type of packing makes a difference.
Pete.
XTC is offline
