Old 29th Jun 2004, 10:52 pm   #1
Leon_Crampin
Default Noisy Philips sets.
The Philips 170A is a big octal valved 1946 radio with an RF stage. My set would tend to become very noisy on LW only, after about 10 minutes operation. The set is full of those splendid Philips "beehive" type trimmers with rotatable caps, sealed (undisturbed from new) with a blob of yellow wax.
In the case of this set, the wax had been applied when too hot, causing it to run down the central spiral stem inside the trimmer, giving rise to an intermittent contact with the trimmer rotor when warmed up. Cleaning off and re-aligning the set cured this fault, and restored its excellent performance. These sets have no lack of gain, despite having no audio pre-amplifier.
Does anyone have any suggestions for a suitable locking compound for this type of trimmer? Silicone rubber does not look very authentic!
Last edited by Paul Stenning; 27th Dec 2004 at 12:27 pm. Reason: Fix link or code for vBulletin
Old 16th Jul 2004, 11:23 pm   #2
ajgriff
ajgriff's Avatar
Default Re: Noisy Philips sets.
Candle wax?
Last edited by Paul Stenning; 27th Dec 2004 at 12:28 pm. Reason: Fix link or code for vBulletin
ajgriff is offline
Old 17th Jul 2004, 8:01 am   #3
high_vacuum_house
high_vacuum_house's Avatar
How about red tamper proof paint, the type used on the heads of screws?
Christopher Capener
Interests in the collection and restoration of Tefifon players and 405 line television
high_vacuum_house is offline
Old 17th Jul 2004, 11:06 am   #4
paulsherwin
paulsherwin's Avatar
Nail varnish?
Paul
paulsherwin is offline
Old 17th Jul 2004, 10:25 pm   #5
Leon_Crampin
Thanks for all of your suggestions, everyone. In fact, after a bit of experimentation on a scrap trimmer, I have settled on making very small felt washers which push over the pointed central stem. I then applied yellow wax as normal, covering the washer completely, locking the trimmer rotor as Philips did.
Surface tension ensures that the wax soaks into the felt, but does not go right through it, preventing it from running down the stem.
No doubt any snags with this scheme will show up after another 50 years.
Regards, Leon.
Old 17th Jul 2004, 11:19 pm   #6
jim_beacon
jim_beacon's Avatar
Anti-tamper varnish is available in red and green from Farnell.
Jim.
jim_beacon is offline
Old 18th Jul 2004, 8:43 am   #7
Sideband
Sideband's Avatar
Hi Leon.
Your idea sounds quite good. I normally use nail varnish (having a 20 year old daughter helps here)! Clear is good and neutral of course but as there are so many outlandish colours available now you could probably find yellow available somewhere.
Rich
Sideband is offline
