27th May 2018, 3:44 pm | #21 |
Re: A little help please! Garrard 40B. Dynatron HFC34.
Ah yes, I see it now by comparing the pic in #15 and #18. If the OP goes ahead with the purchase of a cartridge, we can advise as to the wired connector locations later.
BTW, I have not suggested the use of "red generic chinese cheapies", as the ones with a cartridge mount can cost nearly as much as the more recommended AT91.
Edward. |
27th May 2018, 3:59 pm | #22 |
What Pickering cartridge was it meant for? A common Pickering cartridge (v15) was rebranded as the Stanton 500 series dj cartridge which is very easy to find on eBay, and produces very nice results. I say rebranded, it’s the same body etc anyway which is what matters here
27th May 2018, 10:18 pm | #23 |
Actually the Pickering and Stanton carts have the metal half inch bracket soldered on slightly differently. I cannot use the white D500 styli on my Pickering because there's a metal 'protrusion' that impedes the rather large white plastic upper section, though the other way round is possible.
Solution: the 500v3 stylus fits both!
Regards, Ben. |
27th May 2018, 11:07 pm | #24 |
Interesting, I hadn’t noticed that. For the OPs purposes he should be able to mount a Stanton there no problem if the slide is for a V15
28th May 2018, 6:11 am | #25 |
The Pickering "adapter" was designed to snap into the Garrard C2 cartridge clip. Some judicious prying should remove it. Likely the threads are undamaged. What can be difficult is sourcing the correct screws...I think they are 6BA.
28th May 2018, 10:28 pm | #26 |
Folks, thank you all again! What a plethora of information this forum is! I’m just waiting on delivery of the Headshell, see what the deal is there. After that you reckon my best bet is to get an AT91 and go from there?
30th May 2018, 10:47 pm | #27 |
The Stanton 500V3 is a smoothie in todays standards and works well in Garrards like these. I don't know the dedicated clip for the C2 I'm afraid but if a standard C2 is used, the screws are an imperial? thread not metric. The weight-spacer pictured helps a lot with ceramic cartridges and maybe the 40B as well, as the counterweight is fixed on this one, relying on a spring for much of the work. Sorry I can't help any more than this. The AT91 (or posher Rega Carbon) is an excellent cartridge (forget the low price for a minute) and at 2g tracking if the arm and trip mechanism is in good order, sounds and measures surprisingly well. Both the above are rather less 'foggy toned' in my opinion than the G850 now.
Best wishes, Dave |
12th Jun 2018, 4:53 pm | #28 |
Hi all, so the C2 and mount have been delivered (there’s actually 2 Pickering mounts one with a B on and one with a D) I’ve enclosed a pic anyway...
What’s my next step? As you can see the C2 is wired with connectors, the thread looks undamaged too. Thanks again for all your help |
12th Jun 2018, 5:38 pm | #29 |
Well the next step will be to connect those 4 leads to the 4 pins on your cartridge - assuming you now have bought one. Many suggested you go for the Audio technica AT91.
Edward. |
